Arborwear
Author Topic: mixing species in kiln  (Read 430 times)
Offline xlogger
« on: December 17, 2017, 05:39:14 AM »
I cut a fair amount of live edge slabs here and sometimes take the pith cuts out and resaw back into thick quartersawn lumber. I was thinking in the future maybe going ahead and cutting out 4 or 5 thinner boards out of the slab logs for quartersawn boards and putting on different pallet for drying. But I would have several different species on the pallet for kiln drying later when they air dry down. Would it hurt to dry this all down to around 7-8% together or how has anyone handled this, without unloading the kiln in stages?
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: mixing species in kiln
« Reply #1 on: December 17, 2017, 07:36:54 AM »
If they are the same thickness and ingoing M%, I mix them.
Offline YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
« Reply #2 on: December 17, 2017, 08:14:20 AM »
I do it also, but generally have separate working partial pallets for different wood.  I will just add it to the incomplete pallet until it fills up, especially stuff I can't mill in large enough quantities at a single session to get a full pallet.  Once reasonably air dried, I mix palleted species in the kiln based on general type.
HobbyHardwoodAlabama.com
Offline GeneWengert-WoodDoc
« Reply #3 on: December 18, 2017, 08:01:13 AM »
Some species can be mixed at high MCs.  You will see mixed species in the basic kiln schedules in Drying Hardwood Lumber, tables 7.11 to 7.21.
At low MCs, such as after air drying, any species and thicknesses can be mixed safely.  Make sure they are at the same MC (within 5% MC) going into the kiln.
Online moodnacreek
  • Sawin by the notches
« Reply #4 on: December 20, 2017, 07:20:21 PM »
Wouldn't  black walnut stain white woods ?
Offline scsmith42
    • Whispering Pines Farm
« Reply #5 on: December 20, 2017, 11:08:23 PM »
Never been an issue for me.
Early on I learned some hard (and expensive) lessons about mixing species in the same DH kiln run from green.  Now in the solar kiln, no problem.  In the Nyle though -  no go.
Once everything is below 15% I routinely mix species and thicknesses, but try to keep the drying rates in synch.  As an example, I wonít finish off 15% 4/4 pine in with 15% 8/4 oak - even if both were air dried.
Tom's 3638D Baker band mill
« Reply #6 on: December 21, 2017, 08:48:50 AM »
I agree, I don't mix green species or thickness unless it's something very similar and forgiving such as poplar and basswood.  Too risky for me.
Mixing Species in Nyle Kiln
Started by DR_Buck on Drying and Processing
Last post July 24, 2007, 11:37:29 PM
by scsmith42
Mixing species when kiln drying?
Started by oakiemac on Sawmills and Milling
Last post December 21, 2003, 05:07:11 AM
by Don_Lewis
Mixing 8/4 and 4/4 in the kiln?
Started by oakiemac on Drying and Processing
Last post November 08, 2004, 04:24:56 PM
by dewwood
Drying different species in a solar kiln
Started by Peakebrook on Drying and Processing
Last post July 25, 2009, 06:36:54 PM
by Peakebrook
