Author Topic: Planning stage of new bandmill build  (Read 2541 times)
Offline rrleesb
« on: December 18, 2017, 09:35:10 PM »
Hi all,
Almost retired Navy man here.  I am kinda  a jack of all trades, but I really enjoy building machines and fabrication.  I have a friend, that lives a few hours away, that has WM LT40 hydraulic.  I've cut quite a bit of wood with him as the guy that pulls the boards off and gets new logs ready.  It's something that I enjoy and could save me some bucks on projects.  I also enjoy timberframing and would like to do more of it.  Building a sawmill will help me accomplish some of those goals.
So, I'm in the planning stages of a sawmill build.  I think I'm going to build a Linn style mill.  I'm going to lay out some of what I'm thinking, feel free to give advise where necessary.  I also have a few questions so take a shot if you have some good info.
My plan is to make it mobile from the start.  The main beams 2x6 3/16 x 24'.  Put a 2x3 3/16 cross beam every 30".  On top of the cross beams put an adjustable 2x2 1/4" bunk similar to the WM decks. I plan to add hydraulics later so I thought the stiff deck was a necessity.  The Linn plan calls for a sharp dog vice just a stop for the cant stops, opinions?  For the carriage rollers are the v pulleys or the u pulleys more effective?
I have a 22hp Predator engine.  It has a 1" shaft.  What should I use for a clutch?  Twin Sheave?  The Linn site lists centrifugal clutch with a 2 sheave 4" but it's a 1 1/8" shaft.  Is there a bushing I can use?
As far as hydraulics go.  An engine driven pump?  What type and displacement?  Flow?  With the 2 sheave clutch, will I need to run a jackshaft to get another sheave?  Electric over hydraulic?  I would still need a sheave to run an alternator wouldn't I?
Any reason to get wheels larger than the 19" ? What benefits are there to using the 21 or 26" wheels?  Sheaves or the Cooks wheels?
Thanks for all the input!
Ryan
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: Planning stage of new bandmill build
« Reply #1 on: December 18, 2017, 10:55:02 PM »
Buy on E-bay. They come with an oversize key.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #2 on: December 19, 2017, 07:39:08 AM »
Sounds exactly like my build I am in the middle of. If you call Linn Lumber they can get you the 1" ID clutch. that is the route I went. It is the same cost either way.
here is the link to my build. It may help you with yours. Good luck and keep updates coming.
http://www.forestryforum.com/board/index.php/topic,97853.msg1511008.html#msg1511008
I have really enjoyed building mine. Now I just need to get back out there and do some more.
I knew what I thought I meant.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #3 on: December 19, 2017, 07:39:41 AM »
KBeitz, thanx for posting that. I did not know those existed.
Offline Kbeitz
    • My Hobbies
« Reply #4 on: December 19, 2017, 09:03:07 AM »
There is a better one that has the key in the bushing but they cost more.
Offline Southside logger
  • Sawing so I can afford to farm.
« Reply #5 on: December 19, 2017, 09:45:01 AM »
rrleesb -
Welcome to the forum and thank you for your service.  As far as hydraulics go, with only 22hp I would look at electric over hydraulic so you don't rob too much from your band energy.  You won't be using the hydraulics all the time so there is no sense in spending energy to pump fluid all the time.
'92 Franklin 170 grapple skidder
'92 Franklin 5000 wheeled buncher
Wicked Awesome Basset Hound * 2
JD 490D with 4 roller FabTek processer / hydraulic hose breaker
Hot wife
Wood Mizer LT35HDG25, Re-saw attachment
Official Member of the BBFC
Offline rrleesb
« Reply #6 on: December 19, 2017, 09:59:11 AM »
rrleesb -
If that's the case, is there a recommended powerpack or pump?  Estimated GPM to look for?  So i'd need to setup an alternator.... 60A?
Offline Crossroads
  • lets make some sawdust
    • Kevin Bales faith family farm and portable sawmill
« Reply #7 on: December 19, 2017, 10:25:29 AM »
When I put hydraulics on my old lt30, I used a 6.5 predator engine to run them with a 3-11 gpm 2 stage pump. It worked great at just over a high idle, but in hind sight, I could have used a smaller pump.
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummings,
Offline Georgia088
  • New to all things sawmill
« Reply #8 on: December 19, 2017, 11:02:15 AM »
Just curious. How many/far apart are you planning to put your jacks to support the bunk when you are sawing?
Offline rrleesb
« Reply #9 on: December 19, 2017, 11:06:30 AM »
I was planning on putting 6 jacks in, 3 on each side.  2 close to the ends, 2 in the middle, and 2 at the other end.
Offline starmac
« Reply #10 on: December 19, 2017, 12:32:40 PM »
Just a thought, but I would do some checking and see if an electric clutch is available that would work.
Offline pineywoods
« Reply #11 on: December 19, 2017, 01:16:54 PM »
Why do you need a clutch ? Just something else to break. Go look at you buddies lt40. Cheap, simple and proven. Hydraulics... do a forum search "home made hydraulics" everything but a log loader. 3-4 gpm pump should be adequate. I tried the dual stage log splitter pump also...don't...I've built 3 of these, I'm fixed, so I use a 3hp electric motor. I know of a couple that were built using a 5hp vertical shaft lawn mower engine to power the pump..
Bandwheel size... It's a big compromise. Build it to use a standard off-the shelf blade length.
Offline starmac
« Reply #12 on: December 19, 2017, 03:30:50 PM »
I think an electric clutch, similar to the auto clutches available on the LT 40 would be a huge improvement over my older LT40.
Offline Crossroads
« Reply #13 on: December 19, 2017, 03:46:10 PM »
I must admit, I really like the auto clutch....
Offline rrleesb
« Reply #14 on: December 19, 2017, 07:07:51 PM »
Yall are great BTW!  Thanks for all the input so far.
Offline starmac
« Reply #15 on: December 19, 2017, 07:23:00 PM »
As far as what size wheels to use, I would want it to fit standard bands which ever way you want to accomplish it because of the cost of bands. That said I would probably go with the new bands for the wide cuts, as I understand the cost difference is minimal, and everybody will be making them.
Offline thecfarm
« Reply #16 on: December 19, 2017, 08:03:58 PM »
I myself have a shoulder that bothers me. There is no way I would or could move a motor,to engage it. Just the reaching part would bother me. I don't do drive thru. The reaching hurts me. I drop a money bag off at night. I get out of my truck to do it. I have one of those clutches,on my sawmill,like a chainsaw clutch. Can't spell it,just press the thottle.
Offline rrleesb
« Reply #17 on: December 19, 2017, 08:09:42 PM »
I got a quote today from BLM for a 3 sheave centrifugal clutch. It was almost $500. Needless to say Ill be fabricating some sort of belt tensioning device.
Offline JB Griffin
« Reply #18 on: December 19, 2017, 08:11:52 PM »
Use the biggest band wheels you can afford. Absolutely bigger is better.
I a HUGE fan of the hyd pump being engine driven, if you aren't going to have hyd feed and up/down you could use a pump with a 12v clutch on it like what they put on trucks with hay beds or dump beds.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
1.8 million bdft sawn with a Baker Dominator and counting.
Offline thecfarm
« Reply #19 on: December 19, 2017, 08:16:25 PM »
centrifugal clutch,so that's how you spell that. Man that seem high,real high.  :o
Thomas Bandsaw is what I have. That is one of the reason I bought it. No way I could saw without a centrifulgal clutch. They have one on all thier mills,I think.
