Arborwear
Author Topic: edger mandrel speed  (Read 370 times)
Offline JB Griffin
edger mandrel speed
« on: December 19, 2017, 08:02:12 PM »
I bought a old frick gang edger and I need to know what the mandrel speed need to be. I think it has 12" saws maybe 14" inserted tooth. With be powered by a 18hp gasser (for now).
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
1.8 million bdft sawn with a Baker Dominator and counting.
Offline moodnacreek
  • Sawin by the notches
Re: edger mandrel speed
« Reply #1 on: December 19, 2017, 08:32:03 PM »
Try 1800 rpm. That's the recommended  speed for my chase with 14" saws. [ mine is running at 2000]
Offline Brian_Rhoad
« Reply #2 on: December 19, 2017, 08:39:24 PM »
The speed recommended in the Frick catalog is 1700 RPM. The feed speed is 100 feet per minute.
Online Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #3 on: December 19, 2017, 08:48:02 PM »
That's moving. Might need to slow it down for 18 hp gas. My ED26 WoodMizer is 80 fpm with 26 hp diesel. The governor will open up with two blades in two inch oak, but it'll do it.
Offline JB Griffin
« Reply #4 on: December 19, 2017, 09:10:51 PM »
Thanks guys. Thats right what I figgered but weren't sure.
18hp ain't as much as I wanted but its what I could afford.  It'll do for now, til I get a 35-40hp diesel to run it and convert it to hyd variable speed feed.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #5 on: December 19, 2017, 09:17:26 PM »
I'm doing fine with 14 hp. 2" oak no problem. Just got to keep the belts tight.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline JB Griffin
« Reply #6 on: December 19, 2017, 09:31:06 PM »
You might not be in as much of a hurry either. Plus my inserted tooth saws pull a fair bit wider kerf than the set tooth saws Belsaw used.
Offline Kbeitz
    • My Hobbies
« Reply #7 on: December 20, 2017, 06:13:44 AM »
I don't have the inserted tooth but I do have carbide wide tips.
But yes my saw is not what I would call fast...
Edger Blade Speed
Started by Bro. Noble on Sawmills and Milling
Last post May 03, 2003, 09:34:25 PM
by Dugsaws
WM edger Motor speed
Started by AusLJW on Sawmills and Milling
Last post February 11, 2008, 09:17:36 AM
by sparks
L/h - r/h sawmill mandrel
Started by moodnacreek on Sawmills and Milling
Last post December 23, 2017, 09:22:14 AM
by moodnacreek
mandrel tachometer
Started by lyle niemi on Sawmills and Milling
Last post April 27, 2012, 07:28:20 AM
by dave9252
