Author Topic: New wood stove  (Read 904 times)
Offline Jerryok1971
New wood stove
« on: December 20, 2017, 09:33:22 AM »
Hello all. I am a new wood stove user and was wondering if anyone knows how long it takes for a cast iron wood stove to cure. The Manuel said it could give off a smell when first used and his is normal. I have built 3 small fires so far and it is still giving off a unpleasant odor. I'm burning dry 2 year old maple and cherry. Any info would be greatly appreciated.  Thanks, Jerry
Offline GRANITEstateMP
  • LIVE FREE OR DIE
Re: New wood stove
« Reply #1 on: December 20, 2017, 11:05:14 AM »
Jerry,
  Your probably just about there.  Between burning off the stove, and the stove pipe, it takes a bit.  I'm assuming the pipe going to the chimney is new also?  How about the chimney, is it masonry or pipe?  If you've already had a few small ones maybe one more good, hot one and you'll be smell and smoke free.
Hakki Pilke 1x37
Kubota M6040
Load Trail 12ft Dump Trailer
2015 GMC 3500HD SRW
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
Re: New wood stove
« Reply #2 on: December 20, 2017, 11:11:13 AM »
Get it hot.  Just like seasoning a cast iron frying pan ;) 8) :)
Offline Jerryok1971
Re: New wood stove
« Reply #3 on: December 20, 2017, 11:32:35 AM »
Thanks Grant and Corley. Grant, yes the pipe is new also. The chimney is lined with 316 Rockflex lining and wrapped in insulation. I have built 3 small fires as per the instructions of the stove progressively bigger each time but nothing really hot or big so far. It supposed to get into the teens tonight so I think that big fore will be on order. Thanks again
  • LIVE FREE OR DIE
Re: New wood stove
« Reply #4 on: December 20, 2017, 04:18:55 PM »
  Teens tonight?  Yip, get her hot!  Worst case open a couple windows, the smoke (there is always smoke) and smell will be gone before ya know it!  This time tommorow you won't have to think about it again, till ya need to replace pipe!
Good luck,
Matt
Hakki Pilke 1x37
Kubota M6040
2015 GMC 3500HD SRW
Offline Woodcutter_Mo
Re: New wood stove
« Reply #5 on: December 26, 2017, 08:28:47 PM »
 I did a pre burn fire in my new outdoor furnace and it smelled for several hours. I let it burn pretty warm for the rest of the day and it seems to have quit smelling now.
 On a side note, years ago when we put the new Ashley circulator stove in, the top panel had a little plastic handle that was supposed to be installed on the outside/top but was installed inside the top cover for shipping. We forgot to remove and re-install the handle and it melted inside and the blower fan blew strands of melted plastic clear across the house. The melted plastic stunk and even now 15+ years later when there is an exceptionally hot fire going it will still have a slight plastic smell.
 Wouldn't hurt to double check everything.
- WoodMizer LT25, Kohler, all manual, old "drag" style WoodMizer sharpener, cat claw single  setter
- Husqvarna 372XP X-Torque/24" bar, 455 Rancher X-Torque/20" bar, 550XP/20" bar, Stihl 024AV/18" Oregon speedcut
- Kioti DK45, '92 Dodge Cummins with Cannonball  bed, '07 Honda Rancher
Offline Peter Drouin
    • A&P Saw mill LLC
Re: New wood stove
« Reply #6 on: December 31, 2017, 08:17:54 AM »
We always set the stove up outside and let it rip for the day, Then bring it in.
Let it rip with the windows open, or bring it outside.
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
wood stove ban..
Started by york on Firewood and Wood Heating
Last post January 11, 2009, 08:47:52 AM
by SwampDonkey
Help with a wood stove
Started by peter nap on Firewood and Wood Heating
Last post January 20, 2008, 08:40:51 AM
by peter nap
DIY wood stove ....
Started by TexasTimbers on General Board
Last post February 23, 2006, 10:53:45 PM
by UNCLEBUCK
CB wood stove
Started by coxy on Firewood and Wood Heating
Last post September 30, 2016, 08:25:54 PM
by DDW_OR
