EZ Boardwalk Sawmills. More Saw For Less Money! sponsored by Northeast STIHL
Author Topic: Cement board backer on wrap and strap  (Read 338 times)
Offline dfvellone
« on: December 21, 2017, 08:57:26 AM »
My timber frame wrap and strap has 2 1/2" of xps on the exterior and I'm beginning the 4" strapping soon. Being built on a slab-on-grade I won't be starting my wood siding at grade, but 24" above. That 24" space from grade to siding will get a 10" stone veneer. With masonry and moisture considerations in mind I won't be running the wood strapping down to grade, but will terminate it at the 24" above grade mark. I was thinking I'd either rip cement board down and use it as the strapping behind the stone work (with diamond lath attached for backer), or use the cement board as a continuous 24" backer.
I'd greatly appreciate your thoughts and input. Thanks
Offline kantuckid
Re: Cement board backer on wrap and strap
« Reply #1 on: December 31, 2017, 11:55:22 AM »
A bit off the post but in looking on CL for a used cement mixer i saw lots of cement boards for sale-huge stacks of the stuff!
Board and Batten + Wrap and Strap
Started by John P. on Timber Framing/Log construction
Last post June 24, 2017, 10:22:59 PM
by Magicman
wrap and strap
Started by logman on Timber Framing/Log construction
Last post May 21, 2017, 10:26:16 PM
by ljohnsaw
Wrap and Strap, from a newbie
Started by tburch on Timber Framing/Log construction
Last post May 01, 2014, 07:03:07 PM
by Brian_Weekley
Wrap and strap tape for xps
Started by dfvellone on Timber Framing/Log construction
Last post July 13, 2017, 05:32:56 PM
by timberwrestler
