Arborwear
Author Topic: Wood heat, propane chimney  (Read 316 times)
Online quilbilly
« on: December 21, 2017, 08:58:16 AM »
So we bought a house last year and got through a mild winter with electric. Our house was set up for a propane stove with a chimney etc. My issue is I have gobs of firewood, a free wood stove, and want to go with wood. After pricing out double wall and a support kit for piping through the chimney we were around a grand. If I don't go through the chimney I've got about 8 feet to the cieling. So do I buy a propane stove, go with straight pipe and cut a hole in the roof, or another option. I saw a Kimberly stove doesn't need triple insulated pipe but costs about 4k.
a man is strongest on his knees
Offline bluthum
  • Tick magnet.
Re: Wood heat, propane chimney
« Reply #1 on: December 21, 2017, 09:30:50 AM »
What ever you do don't put wood stove exhaust through a propane chimney.
Wood heat is wonderful but needs to be managed with great respect.
 I like to think about it as if I'm building a fire in the middle of the house, that helps keep me careful.
Offline gasman1075
  • I'm lucky
« Reply #2 on: December 21, 2017, 02:56:08 PM »
If you have a B vent chimney designed for LP or natural gas a wood stove vented into it will melt it. If you have a masonry chimney with a flexible liner for gas could you re-line with SS for wood ? Class A pipe through the roof is best but is certainly expensive. A chimney vent gas stove wont be more than 80% efficient and probably less than that. I have serviced and installed gas and wood stoves so if you sent a few pictures I could weigh in if need be.
Jack
JD 790/Stihl MS310/Stihl MS261/ MS 461 / Timberwolf TW-P5/ Norwood Skid-Winch
Offline hedgerow
« Reply #3 on: December 21, 2017, 07:42:37 PM »
The first call I would make would be to the house insurance company and see if they will let you even install a wood stove. Around here hard to get insurance on a house with a wood stove and if you do the chimney needs to be up to code.
Online quilbilly
« Reply #4 on: December 24, 2017, 11:18:29 AM »
I just bought a used lp stove that will hook up to what I have. The savings in cost oughta pay for a couple of years worth of fuel.
Chimney fire warning for those who heat with wood
Started by kevin19343 on General Board
Last post January 22, 2014, 08:45:38 AM
by maple flats
AHS Wood Gun - Ash out the chimney
Started by eesiason on Firewood and Wood Heating
Last post June 25, 2014, 08:36:07 PM
by 711ac
Wood stove chimney question
Started by billyO on Firewood and Wood Heating
Last post August 28, 2011, 06:59:05 AM
by Al_Smith
Chimney on outdoor wood furnace
Started by Woodcutter_Mo on Firewood and Wood Heating
Last post November 25, 2017, 11:50:52 PM
by Woodcutter_Mo
