Author Topic: Mounts for gas engine on homebuilt bandsaw mill?  (Read 1275 times)
Offline AncientTom
  • An old fart living in the Ozarks.
    • My LinkedIn profile.
« on: December 23, 2017, 12:17:25 PM »
I am thinking on building a small band saw mill after the Christmas holidays. I purchased a Harbour Freight gas engine for this project and fired it up. It has an amount of vibration but that is to be expected.
I have been educating myself for the past several weeks watching all the videos on professional and home brewed saw mills that I can find. In all the videos I've watched I have not seen anything about shock mounting the engine when mounting it on the frame.
My question is, is this something to be concerned about?  If I do try to isolate the engine vibration from the saw frame, will the dancing of the engine independent of the saw frame create problems in the tensioning of the drive belt?
Offline Den-Den
    • Dennis Wood Art
Re: Mounts for gas engine on homebuilt bandsaw mill?
« Reply #1 on: December 23, 2017, 12:21:47 PM »
Mine is bolted down solid, no issues.  A little flex in the motor mounting should be OK but you should limit how much it can "dance".
Offline AncientTom
« Reply #2 on: December 23, 2017, 12:41:12 PM »
If I use rubber isolation mounts, would you think that a spring loaded idler wheel on the belt might minimize the resulting dancing slop in the belt tension?
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #3 on: December 23, 2017, 12:42:32 PM »
Welcome to the Forestry Forum,  AncientTom!
I don't think you would want to allow much movement in the engine mounting system!
The reason being, it's going to move when the blade is engaged!
Most sawmills I've seen, the engine is allowed minimal movement, or none!
The engine on my LT40 had rubber bushings in the mounting system, but when they went bad, I installed the aluminum ones with the brass bushing in the middle, thus eliminating any movement!
~Chuck~
I LOVE MY SAWMILL
Offline AncientTom
« Reply #4 on: December 23, 2017, 01:15:57 PM »
Okay then I will hard mount it to  the frame and hope for the best.
Offline starmac
« Reply #5 on: December 23, 2017, 06:15:49 PM »
I would not mount it solid, even minute flexing can crack the block, there has to be some give somewhere.
Offline hamish
« Reply #6 on: December 23, 2017, 07:39:43 PM »
The give is in the PTO side of things, be it the belt or spider etc....
Norwood ML26, Jonsered 2152, Husqvarna 353, 346,555,372,576
Offline Gearbox
« Reply #7 on: December 23, 2017, 08:06:42 PM »
I have a HF 13 bolted solid on the home built processer . Wore out a 11 HP Briggs . It is pulled down all kinds of woods roads and main roads . No way a sawmill is going to get treated like that .
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #8 on: December 23, 2017, 08:14:12 PM »
13hp Honda bolted solid to 12" wide x 3/8" thick channel. No problems.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline AncientTom
« Reply #9 on: December 24, 2017, 03:37:26 PM »
Don't know what kind of device your processor might be and how it relates to the engine vibration effect would be on a band saw mill log cut???
Offline AncientTom
« Reply #10 on: December 24, 2017, 03:38:44 PM »
Offline Kwill
  • Cedar cutter
« Reply #11 on: December 24, 2017, 09:13:14 PM »
I'm in the middle of my build also. I plan on bolting my solid also. I see your over by phillipsburg. Not to far away.
Built my own log arch
In the process of building my sawmill
Offline Gearbox
« Reply #12 on: December 24, 2017, 09:30:44 PM »
What I am saying is there is a lot more stresses hauling an engine on something going down a road at 60 MPH than you will ever put on a band mill . Build it like you want .
Offline AncientTom
« Reply #13 on: December 25, 2017, 01:07:43 PM »
... I see your over by phillipsburg. Not to far away.
That fish you are holding up looks like it's from my pond, caught in my neighbor's pond. My neighbor has all my fish now because last spring, my pond's dam gave way. If it weren't for the loan I am paying off now to rebuild my dam, I would be tempted to buy a Wood Mizer mill. As good as WM is, I think that I can do better for a lot less money.
Offline AncientTom
« Reply #14 on: December 25, 2017, 01:13:40 PM »
Thank you for the clarification. My concern is not for the structural integrity of the mill frame, it's for the possibility of the engine vibration disturbing the stability of the blade cutting through the log.
Offline Kwill
  • Cedar cutter
« Reply #15 on: December 25, 2017, 10:42:41 PM »
that big crappie came out of pomme de terre
Offline bandmiller2
« Reply #16 on: December 26, 2017, 06:41:50 AM »
Could use po-boy engine mounts, thats  hockey pucks with a hole in the middle. Most mills I've seen are just bolted to a good flat base. Frank C.
Offline AncientTom
« Reply #17 on: December 26, 2017, 12:51:24 PM »
 :new_year:
question
Thinking of Homebuilt vertical bandsaw mill
Started by Lost Pines on Sawmills and Milling
Last post November 12, 2005, 10:50:36 PM
by wiam
Clutch for engine on homebuilt bandmill.
Started by Andre on Sawmills and Milling
Last post November 21, 2002, 04:39:11 AM
by Andre
Homebuilt Band Mill
Started by J_T on Sawmills and Milling
Last post April 06, 2005, 10:25:02 PM
by J_T
Finished my homebuilt mill, finally.
Started by chevytrucking on Sawmills and Milling
Last post November 17, 2017, 07:12:14 PM
by brianb88
