Arborwear
Author Topic: Hello from Arkansas  (Read 1081 times)
Offline Ratwagen
Hello from Arkansas
« on: December 23, 2017, 06:34:48 PM »
Hello folks, im a newbie to your forum and am starting to build my own bandsaw mill after pricing the lumber cost for a barn i am building. as of now it is mainly in the design stage(using google sketch up), except for a bit of metal that i bought new from a local steel place here in western arkansas. I would love any advice that anyone has to offer and i am full of questions after looking at pictures and watching videos on youtube. My primary design comes from watching a youtube video of user BrotherBCoy. i am using 2 1/2" 3/16 wall tube and 3" 3/16 wall for the carriage along with some 1" x 1" angle 1/4" thick. and some 3/8" steel plate.
question 1: Can your toe adjustment and tension adjument be on the same side of the mill?
question 2: When running trailer tires for band wheels is a 4.80 x 12 suffient enough for a hobby mill?
question 3: Is there a way i can post what i have designed from sketchup for others to critique?
im sure i will have more questions once i start putting an arc to steel and truly building something. Thanks for having me on the forum guys ........ A.j.
Offline Lawg Dawg
  • True South Sawmill Lumber
Re: Hello from Arkansas
« Reply #1 on: December 23, 2017, 07:18:51 PM »
Welcome to the forestry forum. ..dig your heels in,  you'll find everything you need to know here
LT 40 Wide 999cc
John Deere 4000, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong.
True South Sawmill Lumber,  located  approximately 45 miles south of Charlotte, NC
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #2 on: December 23, 2017, 08:22:35 PM »
question 1 .... Yes
question 2 ... Bigger's  better. Small diameter will brake bands.
question 3 ... Yes
question 4 ... I'm sure you got more...
My mill build link...
http://www.forestryforum.com/board/index.php/topic,82853.0.html
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Ratwagen
« Reply #3 on: December 23, 2017, 09:58:27 PM »
design pics
Offline barbender
« Reply #4 on: December 23, 2017, 11:26:46 PM »
I would advise against using the steel "tube in a tube" method for the head movement, it will give you problems in my experience. Examine a Woodmizer LT15 with the "Semi-cantilever" head, I think that design is a better way to go.
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #5 on: December 24, 2017, 02:19:25 AM »
Welcome to the forum, you have come to the right place to get your questions answered.
1992 LT40HD
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #6 on: December 24, 2017, 08:10:20 AM »
Welcome to the Forestry Forum, Ratwagen!
~Chuck~
I LOVE MY SAWMILL
Offline Den-Den
    • Dennis Wood Art
« Reply #7 on: December 24, 2017, 08:21:55 AM »
I would use larger tires than 4.8 x 12, nothing less than 20" outside diameter.  The tension on the blade will load the tires, wheels and axles as if they were on a 2500 - 3000 lb trailer.
Offline Hilltop366
« Reply #8 on: December 24, 2017, 09:09:24 AM »
Greetings from Nova Scotia!
I would be tempted to add a second horizontal cross piece (yellow in picture) as close as possible to the tires to reduce flex, as the blade is tensioned it will pull the tires together which will make setting up the tracking more difficult, (think floor truss laying on it's side) also moving the bearing closer to the hub will reduce strain on the axel shaft and bearing.
Bracing on the frame to reduce sideways flexing when cutting, something I have seen in videos when the cut is started and the saw head starts wiggling side to side, makes for a lot of extra strain on everything and a ruff cut.
Offline Kbeitz
    • My Hobbies
« Reply #9 on: December 24, 2017, 10:15:23 AM »
I made a few mods...
Offline Crossroads
  • lets make some sawdust
« Reply #10 on: December 24, 2017, 11:22:46 AM »
Welcome and have fun with you project
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummings,
Offline ScottAR
  • eat mo' ribs...
    • n/a
« Reply #11 on: December 24, 2017, 12:34:31 PM »
Welcome to the forum!
Scott
[Magicman]
Offline JRWoodchuck
« Reply #12 on: December 26, 2017, 02:11:25 PM »
My mill head is tube over tube and works well. The longer the outside tube the better. It will create less fore and aft movement and help with binding while lifting the head. As everyone else has said larger wheels.
Home built bandsaw mill still trying find the owners manual!
Offline petefrom bearswamp
  • made 70-10 and still feelin pretty darned good!
« Reply #13 on: December 27, 2017, 08:44:12 AM »
welcome from the swamp
Keep us up to date on the project
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
In Arkansas
Started by Texas Ranger on General Board
Last post August 26, 2015, 03:18:29 PM
by Ozarker
question
You boys in Arkansas okay??
Started by Warbird on General Board
Last post April 27, 2011, 12:03:13 AM
by LeeB
Arkansas hounds.
Started by Texas Ranger on The Outdoor Board
Last post January 19, 2006, 01:57:39 PM
by Texas Ranger
Arkansas Trip
Started by Corley5 on General Board
Last post March 29, 2005, 09:36:26 PM
by Furby
