I use a red grease and it's a moly grease...For stopped up fitting I use a grease hammer.
Quote from: Kbeitz on December 25, 2017, 05:04:05 PMI use a red grease and it's a moly grease...For stopped up fitting I use a grease hammer.Never seen one of them, must need sandpaper gloves to swing it. Just kidding.....now show me your grease hammer... Merry Christmas
You would need to tell that to the folks that make grease. (Image hidden from quote, click to view.) The grease that I use on my sawmill says Lithium and Wheel Bearing. (Image hidden from quote, click to view.) The key wording is: NLGI #2. What I found out is that it will not harden and clog the sawmill's grease fittings.
Started by Jeff on Sawmills and Milling
Started by MartyParsons on Sawmills and Milling
Started by delvis on Sawmills and Milling
Started by Magicman on Sawmills and Milling
