EZ Boardwalk Sawmills. More Saw For Less Money! sponsored by Northeast STIHL
Author Topic: Service on Wood Mizer  (Read 2529 times)
Offline woodmills1
  • the truth shall set you free
Re: Service on Wood Mizer
« Reply #40 on: December 28, 2017, 02:09:41 PM »
my grease hammer worked pretty good til I put it down one day and, well you know the rest.
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
« Reply #41 on: December 28, 2017, 02:25:16 PM »
When you say mobil, are you talking about their synthetic?
Whatever the delvac is
Boy, back in my day..
Offline landscraper
  • LT4H0DD47. Dyna SC14.
« Reply #42 on: December 28, 2017, 09:20:31 PM »
X2 on Mobil Delvac Extreme.  I buy it by the case at Cat, ends up at about $4.50 a tube, cheap enough for good grease.  I could save a buck a tube at the fleet & farm place but if the machine I'm greasing costs 5-6 figures, what's a buck?
Firewood is energy independence on a personal scale.
Offline Haole Dave
  • Member*
« Reply #43 on: December 30, 2017, 10:51:00 PM »
Marty, can you tell me where I would find the fuse for the lube mizer on my 2016 LT40?
Offline whatwas
« Reply #44 on: December 31, 2017, 09:26:30 AM »
I bought this grease gun fitting at the John Deere nortrax and it works great!! It will seal up and lock on like no other fitting. It will even snuff the battery operated grease gun before leaking. It seemed expensive at the time $45 but has saved a ton of time and honestly, I'm sure has got grease to fittings that might have got the (I'll get back to that later) thing.
I was taught from a ole time rock crusher guy to try to grease while shafts/bearings are turning/running (dangerous I know, I know) but this thing minimizes "hands on" time.
life is good
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #45 on: December 31, 2017, 10:37:13 AM »
I have one of these and use WD40 in it.   Works great.
(Image hidden from quote, click to view.)(Image hidden from quote, click to view.)
I bought 2 of these while at Paul Bunyan this year.   I have not used then yet.   In fact I may never use them.  I packed then to move and have no idea where they are now.    :D     Still lots of stuff in boxes until the garage and shop are finished.
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40HDG38
Lucas Dedicated 60" Slabber
Online MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
« Reply #46 on: January 01, 2018, 08:59:58 PM »
The fuse is located behind the Lube Mizer switches. Should be 4 Phillips head screws.
Fuse should be 2 ATO Grey and 4 ATO Pink.
The 4 amp goes to the Pump
The 2 amp is for the timer module.
Best to unhook the red wire to the pump before turning on after you replace the fuse. If it still trips then it is the wiring. ( Not very common ) You then know the pump caused the fuse to blow. Winter time pump is frozen, or the pump does not like to be inactive for long times. The pump magnets will rust to the armature, if the pump runs it burns off the moisture and runs for ever.  :o well almost. You get what I am saying?
I have not had much luck removing the pump and dissembling it to fix the issue. Is has happened though.
Hope this helps.
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
Wood-Mizer Service Tour
Started by gfadvm on Sawmills and Milling
Last post June 12, 2014, 09:18:24 PM
by Magicman
Wood-Mizer Service Route
Started by Magicman on Sawmills and Milling
Last post January 24, 2014, 02:53:20 PM
by Magicman
Service on a Wood Mizer mill.
Started by MartyParsons on Sawmills and Milling
Last post March 19, 2016, 05:52:18 AM
by MartyParsons
Thank you Wood Mizer customer service
Started by delvis on Sawmills and Milling
Last post July 08, 2014, 11:32:57 PM
