Author Topic: tree marking paint  (Read 939 times)
Offline Coconut
  • Raised on saw dust
tree marking paint
« on: December 27, 2017, 06:04:53 PM »
 Hi All, Can someone tell me what kind of paint to use for marking during the winter ?
Offline Oldmil
Re: tree marking paint
« Reply #1 on: December 27, 2017, 07:32:20 PM »
We use Nelson paint year 'round.  We use Trecoder paint guns for the quart cans.  In the past, I used the Nelson guns and we would cut the paint with diesel fuel (approx. 25% diesel). I don't cut the paint when using the Trecoder guns. I believe the Nelson paint is petroleum based so it will not freeze (I had some in the bed of my truck for several hours today at -15 deg F, no problems).  I haven't used Bark Mark paint but was told it is water based so would need to be kept warm until put on the gun.
Hope this helps.
Oldmil
Offline Clark
« Reply #2 on: December 27, 2017, 10:49:53 PM »
I always use Bark Mark but avoid marking in the winter. I've been told you can add, similar to the diesel with Nelspot, windshield washer fluid rated for cold temps and spray just fine to 0║F.
Clark
SAF Certified Forester
Offline Ron Scott
« Reply #3 on: December 28, 2017, 01:56:39 PM »
Primarily use Nelson Paints and some Tree Coder Paints. It is water based so do need to thin it down with a little paint thinner in the winter. Use the Nelson Paint guns with the larger nozzle and carry a thin wire to open up the nozzle should it freeze shut or become clogged with snow. When it gets down around zero I will warm the paint up with a Buddy Heater on the tail gate of the truck.
As the snow gets deeper the tree stumps will need to be opened up with your foot or a paddle for painting the stump mark. Snowshoes are also used for travel. ;)
Winter marking is not as productive so try to avoid it as much as possible and only work the better weather days.
~Ron
Offline Raider Bill
  • Who will pull the wagon when everyone rides?
« Reply #4 on: December 28, 2017, 02:33:19 PM »
Last Thanksgiving Wild Bill and I marked my property lines with purple rustolem spray primer/ paint as Tennessee had just passed the purple paint law.
Think it will last? I laid it on pretty thick into the bark.
The First 60 years of childhood is always the hardest.
Offline petefrom bearswamp
  • made 70-10 and still feelin pretty darned good!
« Reply #5 on: December 28, 2017, 03:52:13 PM »
I used the Nelson gun with the larger nozzle.
Marketed my own brand of paint for 10 or so years formulated by a local paint company.
It worked well with the larger nozzle down to -10 which was the coldest I ever marked that I can remember.
When in deep snow i used a sidewalk ice chopper with dbh marked on the handle to clear for stump marks determine dbh and help with balance.
I once did a job when the snow was only 6" deep but it snowed 3-1/2 feet right after and the buyers couldnt see the marks.
I then modified my marking height to what i thought was about 6' from the ground.
I have used bark mark, Nelson and tree ink as well as my own brand in my career.
My blue was extremely durable and lasted in excess of 20 years on some of the property lines I marked.
My supplier went out of business tho and sold the formulas to another outfit that wants $25 per gallon in 500 gallon lots.
Bill, I have no clue on the rustoleum.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline Coconut
« Reply #6 on: January 02, 2018, 08:01:11 PM »
Thank you all.In regards to  your reply. Big help. I will not be marking any time soon.It has been around 20 to  -20 f  It has been this cold from my first post.  Thanks again!
Offline Shickory
  • Member*
« Reply #7 on: January 06, 2018, 07:42:47 AM »
Nelson paint works well to -12 C after that the last 40% of the can sputters making stump marks frustratingly slow. I carry a D shovel handle with shovel removed and replaced with and old WIA sign. A piece is cut out of the sign  that is  15 cms long and 6 cms at stump marking end with a slight curve opposite of tree curve. I wrapped and bolted the metal to wooden shovel handle leaving 10 cm protruding below end of wooden handle. Works well can actually carve bark if required. Marking in snow creates better visibility for harvestors because of the added height of snow.
Tree Marking Paint
Started by KBforester on Ask The Forester
Last post August 22, 2011, 04:43:06 PM
by Ron Scott
Tree marking paint for leave trees
Started by wmrussel on Ask The Forester
Last post September 27, 2012, 06:02:40 AM
by Phorester
Log marking paint
Started by mjeselskis on Forestry and Logging
Last post February 16, 2011, 05:27:02 AM
by Ron Wenrich
Tree marking
Started by bendjoseph on Firewood and Wood Heating
Last post February 04, 2013, 05:23:10 PM
by proteus
