Arborwear
Author Topic: Mobil dimension saw mill trouble with forward feed  (Read 434 times)
Offline strider
  • Member*
« on: December 27, 2017, 06:08:26 PM »
I have an older mill and having a problem that the mill won't move forward on its own. It has new belts, might be the clutch that grabs the belt.
Offline DanG
Re: Mobil dimension saw mill trouble with forward feed
« Reply #1 on: December 28, 2017, 01:11:04 AM »
Welcome to the forum, Strider.  It sounds like you have a model 127. I have a 128 with hydrostatic feed and don't know anything about the 127. I think Paul-H used to have a 127. I'll give him a heads up. ;)
Offline fishpharmer
« Reply #2 on: December 28, 2017, 06:10:01 AM »
Strider, welcome to FF!  This is a great place with great folks.  I mainly wanted to say welcome since I know little about Mobile Dimension mills.  The only Mobile Dimension mill I have seen in operation up close is DanG’s,  its an impressive machine. 8)
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #3 on: December 28, 2017, 06:33:44 AM »
Welcome to the Forestry Forum, strider!
~Chuck~
I LOVE MY SAWMILL
Offline starmac
« Reply #4 on: December 28, 2017, 05:13:25 PM »
Have you contacted  MD directly,  I have no personal experience with them, but from what I have heard they can be very helpful to owners of their mills.
We have some very experienced  members  with md mills, but they are not very active on the site.
Offline J R Bradshaw
« Reply #5 on: December 28, 2017, 08:56:21 PM »
I have a MD 127 that had the same problem last month, I had not sawed in quite a while.  Turned out it was the plastic variable pulley.  I sprayed a small amount or penetrating oil in the pulley and let the clutch out to slow feed and kept messing and it eventually freed up.  Hope this helps.
J. R. Bradshaw
Offline Daren12
« Reply #6 on: December 28, 2017, 09:08:10 PM »
Nice to see you have a bullet proof MD mill.  127 is 40 years old. Ron at Md great guy to deal with, but chances its been modified.  Try your cable that engages might be slack.  That would be my first try.  I may have other options if that doesnt work.
Daren  :snowball:
127 mobile dimension
1 large saw dust shovel
Offline hacknchop
« Reply #7 on: December 28, 2017, 09:16:28 PM »
Welcome to the forum my first mill was mod 127 and yes it sounds like  your vari drive pulleys maybe worn they will tend to get hollowed out with use you should be able to order new ones from mobile
Often wrong never indoubt
mobil dimension
Started by DKinWA on Sawmills and Milling
Last post July 06, 2008, 08:27:59 PM
by DKinWA
Mighty Mite & Mobil Dimension
Started by Gilman on Sawmills and Milling
Last post January 09, 2006, 10:41:40 AM
by thurlow
woodmizer forward control trouble
Started by sandmar on Sawmills and Milling
Last post July 09, 2008, 08:29:29 PM
by 78NHTFY
forward feed on LT40
Started by Jerry on Sawmills and Milling
Last post January 29, 2011, 05:02:02 PM
by Magicman
