KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: Woodmizer doesn't cut with grain very well  (Read 1898 times)
Offline flatrock58
« on: December 27, 2017, 08:00:56 PM »
My brother in law got a hold of some black walnut yard trees and wanted them cut.  After he finished digging out all the metal we started cutting.  The small and crooked pieces took a while, but we finally got them cut.  He had a couple of 26" diameter pieces that were only 12-18" long, from the butt of the tree.  I told him we could make cookies, but he wanted to just turn it sideways between the clamp and backstop and cut short boards.
 I soon found out that when you crosscut cutting with the grain you don't get nice little sawdust chips, but large noodle like strings that quickly clog up everything.  There were noodles packed tight all around both wheels and blade guides and blocking the sawdust port. After several boards we stopped and cleaned the mill out and turned the log back to the standard orientation. Another lesson learned.
2001 LT40 Super Kubota 42
6' extension
resaw attachment
CBN Sharpener
Piney Woods modified Dual tooth setter.
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: Woodmizer doesn't crosscut very well
« Reply #1 on: December 27, 2017, 09:26:36 PM »
WDH sawed a good many Walnut cookies on his WM.
If he got Noodles he didn't say anything about it.  ;D
Where's the Spoon?
Offline barbender
« Reply #2 on: December 27, 2017, 09:29:50 PM »
That's not crosscutting, that's cutting parallel to the grain.
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
« Reply #3 on: December 27, 2017, 09:38:46 PM »
Ive done that on a chainsaw many times, they call it noodling, that makes some good tinder for starting a fire.
Boy, back in my day..
Offline Southside logger
  • Sawing so I can afford to farm.
« Reply #4 on: December 27, 2017, 09:57:34 PM »
You get in the south and talk about noodlin and it involves catfish, muddy water, swimming, telling the other guy to "hold my beer", and all too often a snapping turtle or nasty snake!!!
'92 Franklin 170 grapple skidder
'92 Franklin 5000 wheeled buncher
Wicked Awesome Basset Hound * 2
JD 490D with 4 roller FabTek processer / hydraulic hose breaker
Hot wife
Wood Mizer LT35HDG25, Re-saw attachment
Official Member of the BBFC
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #5 on: December 28, 2017, 08:01:51 AM »
I don't have any issues like that when cutting cookies.
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
    • THEE Forestry Forum
« Reply #6 on: December 28, 2017, 08:09:38 AM »
Do I understand that you had a short log crosswise on the mill, not standing on end?  That would certainly cause noodles, but as mentioned, that would not be called crosscutting.
Offline flatrock58
« Reply #7 on: December 28, 2017, 08:48:45 AM »
I guess you are right.  It would not be cross cutting.  Cutting with the grain sure does make a mess though.
6' extension
resaw attachment
CBN Sharpener
Offline pineywoods
« Reply #8 on: December 28, 2017, 09:19:03 AM »
X2 on the mess. Been there done that, especially using a good sharp 10 deg blade.
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Woodmizer doesn't cut with grain very well
« Reply #9 on: December 28, 2017, 09:33:16 AM »
   Yep, any type saw will cut those long strips like that in most woods when you cut lengthways. I used to sell a neighbor Norway spruce blocks to make wedges to be used in the coal mines and he said they were one of the worst about making long strips when cut lengthways. Sometimes I get  a nasty crotch that won't split with a maul or wedges and I split them with my chainsaw and I get them then too. Just the nature of wood.
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
« Reply #10 on: December 28, 2017, 09:42:39 AM »
A vertical edger on a circle mill cuts like that as well, however the blade exits the log in it's rotation clearing the gullets, but the chip is long, unlike any other sawdust. The deeper the cut, the longer the string. Our vertical edger had a maximum depth of 3.75 inches.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #11 on: December 28, 2017, 09:44:14 AM »
I've "noodled" may times with a chain saw,  know it well.  Have to clear the sprocket cover and kick the noodles aside on the ground when splitting a log.  Great for hamster bedding if I needed hamster bedding.
But never thought of holding a log like that in 17 yrs on my mill I must say.  To be honest it seems easier than arranging a board and fence to hold it the normal way, at least as far as the clamping goes.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
« Reply #12 on: December 28, 2017, 10:09:45 AM »
Yes, that's what I was thinking too. If the low will fit between the clamp and the fence, much easier to hold it, but looks like there is a major setback to that. :)
That got me thinking, I wonder if you took a hand full of sawdust from most bandsaw mills, and then a handful of sawdust from a mill like the E.Z. boardwalk, that enters the log on an angle, it you could perceive a difference in the dust. (actually chips). Would they be slightly elongated?
Offline paul case
  • Original wearer of the PCM.
« Reply #13 on: December 28, 2017, 12:27:26 PM »
When I switched from the EZ Boardwalk  to the WM LT40 I couldn't tell any difference at all in the sawdust.
PC
pc
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
« Reply #14 on: December 28, 2017, 12:39:35 PM »
Yea, but did ya have a handful of each and really examine It? CSI
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
« Reply #15 on: December 28, 2017, 12:40:38 PM »
Checking sawdust increments.
« Reply #16 on: December 28, 2017, 12:43:29 PM »
Im waiting for that episode of Forensic Files!😀
Offline woodmills1
  • the truth shall set you free
« Reply #17 on: December 28, 2017, 01:57:32 PM »
The few times I have done parallel cutting I thought the noodles looked like the stuff that used to be called excelsior.  https://en.wikipedia.org/wiki/Wood_wool
Offline paul case
« Reply #18 on: December 28, 2017, 06:56:55 PM »
Probably not.
I do notice that since the blower picks up most of the dust from the mill, the only time I really care about the sawdust is when the blower stops working. :-\ :'(
That results in ss. Sawmill sadness that is.
PC
pc
Offline JB Griffin
« Reply #19 on: December 28, 2017, 07:53:41 PM »
PC
That is a great video on youtube, search sawmill sadness. One of if not the fastest mills I've seen.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
1.8 million bdft sawn with a Baker Dominator and counting.
GPS doesn't always know the right way
Started by mahonda on Forestry and Logging
Last post April 22, 2010, 06:28:25 PM
by SwampDonkey
Just doesn't..
Started by HiTech on Forestry and Logging
Last post March 11, 2014, 11:34:52 AM
by sprucebunny
cheesy
something doesn't quite add up....
Started by Dan_Shade on General Board
Last post January 14, 2006, 02:53:02 PM
by Paschale
New guy who doesn't know if he knows what he's doing
Started by Bluejay27 on Sawmills and Milling
Last post July 14, 2014, 10:50:27 PM
by Magicman
