Author Topic: HELP 518 cat cable skidder NO CRANK  (Read 1048 times)
Offline skidinmetimbers
  • Member*
« on: December 27, 2017, 11:50:38 PM »
skidder wont start seems to have power  ran fine now wont start back up  no crank at all
Offline starmac
Re: HELP 518 cat cable skidder NO CRANK
« Reply #1 on: December 28, 2017, 02:08:58 AM »
Won't start or won't crank?
Offline coxy
« Reply #2 on: December 28, 2017, 04:21:46 PM »
what year 518
Offline mike_belben
  • Pulp Friction
« Reply #3 on: December 28, 2017, 11:17:37 PM »
Get your meter out and verify
1. the batteries are charged
2. there is battery voltage at the starter solenoid input lug.
Have someone turn the key and see if you get battery voltage on the solenoid output side.. i.e.. Is the solenoid contacting or is it not.
If its not closing the circuit across the two main lugs, figre out why.  Either it has lost ground, or has lost control voltage or have failed.
Report back your findings and well go from there.
Revelation 3:20
Offline mills
« Reply #4 on: December 29, 2017, 04:16:37 AM »
I've been through a couple of starter motors in mine. The first one was pretty much worn out, but showed signs of moisture getting in. The second was a CAT rebuild, and lasted only two years. It also had moisture damage. Never pressure washed it with direct spray, but now I avoid as much over-spray as possible. This last one is now going on it's fourth year. Another thing is to check your cables, especially where they cross the winch drive shaft. Follow Mike's advice and it should lead you to the problem.
Offline mike_belben
  • Pulp Friction
« Reply #5 on: December 29, 2017, 10:17:49 AM »
Starter motors can usually be broken down and cleaned up enough to revive them.  If the carbon dust from the brushes packs into the commutator segments then they will all have continuity and the rotor stops.  The donkey catches up to the carrot on the stick so to speak.   The only other starter fail i typically see is broken magnets inside the housing from people smashing on them.
But first, verify you have juice past the solenoid and to the starter.  If not we have to troubleshoot the solenoid.
Revelation 3:20
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #6 on: December 29, 2017, 12:30:09 PM »
Check your grounds  ;) ;D :)
Offline snowstorm
« Reply #7 on: December 29, 2017, 12:40:49 PM »
And ground disconnect
Offline pulpco1993
« Reply #8 on: December 31, 2017, 11:42:06 AM »
Look near the injection pump. The fuel shut off solenoid is sticks off. Has wire running to it. Cut key on. Listen for it to click. If it doesn't it is bad and machine want start. It has a button on the back/end that you can manually push in to shut it off or pull out do bypass the electric part and crank it. If i remember correctly.  I know you push it in to manually shut it down
Offline pulpco1993
« Reply #9 on: December 31, 2017, 11:43:45 AM »
You need to people. One listen one turn on ignition.  Get a test light check for power on that wire feeding fuel shut off
Offline coxy
« Reply #10 on: December 31, 2017, 07:18:05 PM »
every 518 iv been around shuts off with the fuel peddle
moved
MOVED: HELP 518 cat cable skidder NO CRANK
Started by chet on General Board
Last post December 28, 2017, 08:58:26 AM
by chet
Cable skidder versus cable dozer
Started by killamplanes on Forestry and Logging
Last post November 15, 2016, 11:24:06 PM
by lynde37avery
moved
MOVED: Cable vs. Grapple/Cable Skidder
Last post November 30, 2005, 09:43:45 PM
by Jeff
question
Started by sticks on Forestry and Logging
Last post December 01, 2005, 05:31:49 PM
by timberjack240
