Author Topic: 540b lost all hydraulics  (Read 1120 times)
Offline colelogging
« on: December 28, 2017, 01:13:51 PM »
While pulling a hitch in second gear(jd 540b)I felt a slight clunk and lost everything related to the hydraulics.No trans,no blade,no steering,winch driveshaft barely turns...fluid level is good....ideas?Gonna be fun getting her out of the woods!
Offline dnash
Re: 540b lost all hydraulics
« Reply #1 on: December 28, 2017, 03:35:57 PM »
Sounds like the clutch. If the winch driveshaft isnít spinning with the eng e, I wuld start there.
JD 540 skidder
JD 640D skidder
Timberjack 205HR
JD CT322 skidsteer
MF 11 loader
NH LS190 skidsteer
Offline coxy
« Reply #2 on: December 28, 2017, 05:07:45 PM »
are the 540s like the 440s with a live pto even when the clutch pushed in the pto still has power
Offline jdeere540a
« Reply #3 on: December 28, 2017, 06:29:58 PM »
Yes coxy they are live like the 440s. It dose sound like the clutch but I don't know why you lost your blade and steering they run of the front pump that runs off the crank
Offline coxy
« Reply #4 on: December 28, 2017, 07:15:10 PM »
it would have to be the pressure plate  even if the clutch disk  went bad the pressure plate is bolted to the fly wheel and it would still have to turn still making the pto live no
Offline coxy
« Reply #5 on: December 28, 2017, 07:18:14 PM »
where are you located I have a almost new clutch and pressure plate you could have I no longer have a use for it  don't know if a 440a is the same but if it is your welcome to it
Offline jdeere540a
« Reply #6 on: December 28, 2017, 08:40:03 PM »
It could have broke the center out of the clutch the foot clutch on a 540 is really a transmission disconnect it dose not disengage the clutch. The lever on the left under the dash that u pull up to aid in cold weather starts is the main clutch disconnect pull that up and trans and winch stop turning.
Offline mike_belben
  • Pulp Friction
« Reply #7 on: December 28, 2017, 09:10:19 PM »
Maybe broke input shaft on the pump or sheared out the keyway or coupler jaws..  Im just throwing darts, dont know the machine.
A broken relief valve spring could do similar.
Does this have a powershift trans that uses exhaust pressure from the hydraulics?  Or does the main hyd valve get fed downstream of the trans?  If the latter, thats a much bigger can of worms.
Revelation 3:20
Offline dnash
« Reply #8 on: December 28, 2017, 09:44:16 PM »
The transmission pump feeds oil to the main pump at the front of the engine. If the driveshaft is not turning or not turning fast enough, the transmission pump will not be able to provide the front pump with the oil it needs which would explain the hydraulic issue. Unfortunately, the only way I can think of to check the clutch is to pull the motor.
JD 540 skidder
JD 640D skidder
Timberjack 205HR
JD CT322 skidsteer
MF 11 loader
NH LS190 skidsteer
Offline treeslayer2003
« Reply #9 on: December 28, 2017, 09:55:34 PM »
before you take any thing apart, check that goofy coupler deere used to drive the main pump.
Offline Southside logger
  • Sawing so I can afford to farm.
« Reply #10 on: December 28, 2017, 10:05:31 PM »
Well, I had a 540A and the priority valve got stuck in between zones and that gave me the same result - nothing hydraulic worked.  I could not find a replacement for it as I guess they all wear out given the design so I simply plumbed around it and my problem was solved.  Not sure if your machine has the same set up or not.
'92 Franklin 170 grapple skidder
'92 Franklin 5000 wheeled buncher
Wicked Awesome Basset Hound * 2
JD 490D with 4 roller FabTek processer / hydraulic hose breaker
Hot wife
Wood Mizer LT35HDG25, Re-saw attachment
Official Member of the BBFC
Offline TeaW
« Reply #11 on: December 29, 2017, 06:37:01 AM »
Had this happen one time with a 440, the pickup pipe on the transmission pump had come off. Good luck.
TeaW
Offline colelogging
« Reply #12 on: December 29, 2017, 07:52:44 AM »
Thanks guys,it does seem clutch related,started machine up yesterday and pulled the disconnect lever up and down......made no difference,no drag on the engine and it was cold(single digits).Got my other 540b moved there,so gonna try to tow her out of woods today.
Offline mike_belben
  • Pulp Friction
« Reply #13 on: December 29, 2017, 12:48:55 PM »
Hopefully its a clutch and and not a snapped or wallowed input
Revelation 3:20
Offline coxy
« Reply #14 on: December 29, 2017, 04:48:18 PM »
if its clutch related you should not be able to shift with out grinding gears right
Offline dnash
« Reply #15 on: December 29, 2017, 05:48:45 PM »
This is a power shift. If the gears are grinding, you have much bigger problems to worry about.  ;D
JD 540 skidder
JD 640D skidder
Timberjack 205HR
JD CT322 skidsteer
MF 11 loader
NH LS190 skidsteer
Offline Maine logger88
  • Don't force it get a bigger hammer
« Reply #16 on: December 29, 2017, 06:11:02 PM »
Mine did the same thing and it was the clutch.
Offline coxy
« Reply #17 on: December 30, 2017, 04:59:39 AM »
  :D  what was I thinking  ::)
540b hydraulics
Started by nyyounggun16 on Forestry and Logging
Last post December 19, 2015, 08:11:08 PM
by grassfed
just lost rear end in JD 540b
Started by robdiesel on Forestry and Logging
Last post March 28, 2013, 08:51:41 AM
by robdiesel
Lost my source, but a family lost its business.
Last post April 25, 2008, 02:16:52 PM
by ely
question
540B
Started by PaYoungBuck on Forestry and Logging
Last post August 30, 2013, 09:14:22 PM
by PaYoungBuck
