Arborwear
Author Topic: half lap rafter peak  (Read 526 times)
Offline Christopher J
« on: December 28, 2017, 09:10:07 PM »
I'm wanting to use half laps for my garden building's roof rafters at the peak. I am doing a 4 in 12 pitched roof. The building is 8' x 12' with the gable ends over the 8-foot sides. I cannot seem to cut the half laps correctly.. so that they mate properly.  I routinely use half laps but never on an angle cut.  If anyone can offer insights I'd very much appreciate it. Thank you.
Online Don P
    • Calculator Index
Re: half lap rafter peak
« Reply #1 on: December 28, 2017, 10:36:06 PM »
Sketchup is an easy way to find angles if that is where the problem is, 36.9.
Offline Roger Nair
« Reply #2 on: December 28, 2017, 10:44:14 PM »
I am guessing you have tried using slope ratios to solve the layout and it was a no go.  To use slopes you will have to draw a level line and then project 4/12 from the level line.  Work at it, you'll get it'
Easier is to convert 4/12 slope into degrees of arc, sketch it out and use geometric reasoning to get the angle.
Easiest is to snap intersecting lines on the deck that correspond to the two roof surfaces, lay down rafters to the lines and transfer marks.
One method is valid as any of the others, be a good student and work through each method, you will profit with understanding.  I know this is vague but struggle will pay off.
An optimist believes this is the best of all possible worlds, the pessimist fears that the optimist is correct.--James Branch Cabell
« Reply #3 on: December 29, 2017, 03:29:44 PM »
Thank you. Pushing ahead. Will let you know!
Offline Roger Nair
« Reply #4 on: December 29, 2017, 08:08:50 PM »
Since it's still early, I'd like to expand one the method of using slope ratios to develop the angles needed for half-lap rafter peaks.  Using Don P's drawing as the visual reference, let's describe the situation from the point of reference of the peak intersection, the rafters descend from the peak by opposite but equal slopes, 4/12.  So when we use slope in layout we are referencing from vertical and horizontal lines or planes.  Keeping the drawing in mind and extending the lines of the rafters in their uncut state, draw a horizontal line through the peak and you will visually see the equal and opposite slope of the two rafters.  Onto the rafter stock, let's assume the rafter seat cuts and rafter length to the peak is known and marked on the rafter stock.  Go to the peak and place the framing square on the rafter with the 12 at the peak and the 4 on the down slope, mark the line from the peak across the stock.  That is the level line reference for the next step.  At this point you might encounter a level line is to short for using 4/12 slope, so you can use any multiple of 1/3, which is the simple root ratio, let's say 2/6 works.  Hold 6 at the peak and 2 from the level line with the slope in a descending direction, mark peak to 2 inch mark.  That should get you everything you need to establish the basic angles.
I hope this can be worked out from my explanation.  Once you see the reasoning, one can handle the problem with carpentry layout tools without need for calculators, trig or computer design tools.
I have edited out a mistake, I am doing this without the aid of a square and a test board.
Online Don P
    • Calculator Index
« Reply #5 on: December 29, 2017, 08:20:01 PM »
I proudly showed Dad some computer calculators I made to give a bunch of roof angle cuts. His response, "It's all on your framing square". But, the first way he showed me to layout a roof was to loft it on the floor full size with chalklines, basically that is what I did with sketchup.
Rafter Peak Joinery
Started by ChiselHead on Timber Framing/Log construction
Last post November 25, 2011, 04:42:38 PM
by ChiselHead
Length of rafter using stepped-lapped rafter seat.
Started by Preserved on Timber Framing/Log construction
Last post June 25, 2011, 06:25:24 PM
by piller
Peak Chilli
Started by Ianab on FOOD! FOOD! FOOD!
Last post May 02, 2018, 08:28:33 PM
by POSTON WIDEHEAD
Peak Oil and Forestry
Started by Tarm on General Board
Last post May 30, 2004, 01:05:24 PM
by SwampDonkey
