Arborwear
Author Topic: Sharpening at -2F  (Read 1148 times)
Offline Peter Drouin
    • A&P Saw mill LLC
Sharpening at -2F
« on: December 28, 2017, 09:24:05 PM »
Too cold to saw. So I put the heat on for 20 min, The place is insulated.
I put on a red marker ink at the weld and on top of the teeth. Gives me a place to start.
I put my blade on the setter and try not to ben the tooth the wrong way. :D :D
set them all at 30 +.--  ;D
I use the same oil that the CBM runs in to oil the blade on the setter.[just the bottom]
This is where the red ink comes in for me, I can't see as good as I use too.
So when I line up the CBN and blade, Then  turn on the oil and CBN wheel. I will have a small adjustment to make so all the ink is gone in the gullet beween the teeth, Then you Know the CBN is centered to the tooth so I can grind evenly.on the blade.
I run it by a little to get where I had it set.
When I done I hold the rag and blade with my right hand, Spind it with my left to the left. All extra oil comes off on the rag. Where all my oil gose.
Run around 6.
Box or two left. Going to be -2
I box them.
1x55x7
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: Sharpening at -2
« Reply #1 on: December 28, 2017, 09:44:45 PM »
Hopefully its -2 F, not -2 from vertical 😄😄😄
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #2 on: December 28, 2017, 09:59:39 PM »
That heater looks like an eyeball.
I don't like it.
Delete it!  :D :D :D
Where's the Spoon?
Offline barbender
« Reply #3 on: December 28, 2017, 10:54:58 PM »
The Eye of Sauron😂😂😂
Offline Percy
  • Resident trouble maker
« Reply #4 on: December 29, 2017, 04:00:18 AM »
eye yi eye .   :D
Offline goose63
« Reply #5 on: December 29, 2017, 09:59:54 AM »
I don't like it.
Delete it!  :D :D :D
David mine burns off road fuel 175 thousand btu's gives a big red eye :)
goose
thank you to all the vets
« Reply #6 on: December 29, 2017, 12:32:25 PM »
I don't like it.
Delete it!  :D :D :D
You have to climb Mount Doom and throw a goat in.
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« Reply #7 on: December 29, 2017, 02:53:32 PM »
Once the picture gets in the post its here foreverrrr.  :D Banjo
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 Logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #8 on: December 29, 2017, 03:46:29 PM »
I leave my bands at the Pack N Ship. FedEx brings them back next week. Works at any temp.  :D
Offline kelLOGg
  • Still learning more than I'm teaching
« Reply #9 on: December 29, 2017, 08:48:02 PM »
-2 from vertical is what I thought it was going to be, too. :-\
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
    • A&P Saw mill LLC
Re: Sharpening at -2F
« Reply #10 on: December 30, 2017, 07:13:25 AM »
-2F  :P
Sawing since 1987
Chain sharpening kit or automatic sharpening
Started by NovaSS on Chainsaws
Last post November 22, 2013, 02:29:18 PM
by thecfarm
Slick sharpening jig, for sharpening slicks.
Started by Dave Shepard on Timber Framing/Log construction
Last post August 21, 2017, 11:15:58 PM
by Andries
To set before or after sharpening
Started by GF on Sawmills and Milling
Last post November 16, 2005, 10:30:03 AM
by GF
Sharpening them up
Started by Magicman on LogRite Tools and Rite Leg Co
Last post June 16, 2014, 08:28:38 PM
by r.man
