Arborwear
Author Topic: Flat bed supplier questions  (Read 984 times)
Offline coalsmok
« on: December 29, 2017, 06:42:19 PM »
Thinking about/looking for a flat bed to put on my f250. Would like to find a steel bed I could put a wood floor in but havenít run across one yet.
 Short of building my own does anyone no of a builder who does this?
Offline thecfarm
Re: Flat bed supplier questions
« Reply #1 on: December 29, 2017, 08:36:17 PM »
If you have one made,make it longer enough so when you shovel something out of the back of the truck,it won't hit the bumper.
Offline hopm
« Reply #2 on: December 29, 2017, 11:24:37 PM »
On the subject of flatbeds.....I took off a utility bed today and have a flat to go back. My problem is the rails on the bed are wider than the truck rails. Do I have an option other than relocate bed rail?
No intention to hijack your thread....It fits and with the expertise of the folks on this board I want answers from as many as I can get
Thanks in advance for any response!!
Offline coalsmok
« Reply #3 on: December 30, 2017, 06:49:19 AM »
Iíd say you would have  to relocate the rails.
I have heard that some of the makers are powder coating the beds. I would honestly rather have paint. Last thing I had on a truck that was powder coated was a brush guard. They when down hill fast. May have been a bad batch but every truck that got one looked Ike crap I a few years.
Offline Gearbox
« Reply #4 on: December 30, 2017, 10:13:23 AM »
Seems like the price of new is a lot of money . Grab 3 or 4 sticks of 3 in channel and go for it . Last I bought it was about $ 60 a 20 ft stick
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
« Reply #5 on: December 30, 2017, 10:23:10 AM »
Try Martin Truck Bodies  Martinsburg PA.
Martinswelding.com
D
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #6 on: December 30, 2017, 11:14:19 AM »
Haven't seen any new ones made that way in a long while.  However, there ought to be some old ones on old trucks sitting in fencerows that could be had pretty cheap.
I'm assuming you planned to use your own wood and don't mind redoing the deck...  In any case, it can be simpler than starting from scratch.
Hopm, sounds like you have a cab and chasis frame at (38ish inches) (makes sense with utility body) and a flatbed made for a standard width truck frame (42 ish inches).  At some point in I think the 60's, most makers widened the frame on light duty trucks (1/2-1ton) to improve the ride.  Cab and chassis models kept the old standard width so commercial truck bodies that would be added could continue being interchanged.
Offline hopm
« Reply #7 on: December 30, 2017, 11:47:28 AM »
Yes sir
Flatbed came off a f350. I'm going on a 450....
Any suggestion? I thought I would be able to move the wood 4x4 on each rail. I don't think that is an option.
Offline barbender
« Reply #8 on: December 30, 2017, 12:05:37 PM »
I've not been impressed with any powder coat paint that I've seen. I have a dump trailer that's powder coated, the paint gets a chip and soon a large patch of paint just falls off. It's not adhered very well.
Offline sprucebunny
  • Gender: Female
« Reply #9 on: December 30, 2017, 01:02:10 PM »
I found this manufacturer in ND
https://www.rugbymfg.com/platform-bodies
It looks you'd need to build your own headache rack .
I have a bed like you'r talking about on an '79 f250 w/ homemade rack.
Offline Carson-saws
« Reply #10 on: December 30, 2017, 01:05:25 PM »
The Felling FT 14 is an outstanding trailer.  They make a number of different lengths and many options.  They can be pintal hitch or ball, tool box, fold down ramps and reasonably priced.
Let the Forest be salvation long before it needs to be
Offline moodnacreek
  • Sawin by the notches
« Reply #11 on: December 30, 2017, 06:57:26 PM »
Wow ! , other people that don't like powder coat, thought I was the only one.
Offline moodnacreek
« Reply #12 on: December 30, 2017, 07:00:35 PM »
I didn't post above post like that and I'm not from the u.p.
Offline thecfarm
« Reply #13 on: December 30, 2017, 07:16:31 PM »
Nothing a matter with being from the U.P.  ;D  Them people that eat grits talk funny too.  ;D
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #14 on: December 31, 2017, 07:04:00 AM »
Lots of good ones at the junkyards....
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline maple flats
  • Life is what you make it!
« Reply #15 on: December 31, 2017, 07:35:11 AM »
2 yrs ago I put a 7x7' aluminum flat bed on my old 2001 F250. Great improvement, but I have a gooseneck hitch under a trap door in the bed. It's aluminum, which I thought would last me forever, but after I bought my current truck, a 2011 F350 I found it could not be mounted on the 2011 without a lot of welding and adapting. The truck or just the bed are listed in the FF classifieds, check if interested. If so, contact me thru a PM. The flat bed has outer rails flat with the bed and stake pockets. It has an aluminum floor. I bought it for $4500 in Jan 2016, used it until June 2017. The truck runs (or did when parked in June, has been started and batteries are out and charged). It's a 7.3 diesel, but the cab is rough.
Offline snowstorm
« Reply #16 on: December 31, 2017, 09:20:47 AM »
You may find the 350 and 450 frame is different
Offline hopm
« Reply #17 on: December 31, 2017, 12:33:52 PM »
The 350 and 450 are different....I'm finding out the hard way. I bought my bed before I pulled the service bed. Found a good deal....was told by several knowledgeable folks the 350 bed was interchangable....as it stands now I am going to either reposition the rails currently on the bed or weld new channel to fit the width of the truck rails. The truck rails are 9" longer than the bed. I can cut 5" off truck rails before I get into moving the gas tank. This leaves me with a 4" gap between headache rack and cab. Not quite sure what I can do. Any suggestion would be MUCH appreciated. I don't really want to buy another bed and then try to sale the one I have and I certainly don't want to wait to sale this one before I buy another. Ideally I would like to find a way to use this one and get rolling.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #18 on: December 31, 2017, 12:37:38 PM »
if you need to make a headache rack then just make it that 4" further forward. Or does this one come with a rack on it already?
I don't know how the mounts are but I would be more inclined to just make new mounts to sit on the current frame.
I knew what I thought I meant.
Offline hopm
« Reply #19 on: December 31, 2017, 04:26:18 PM »
Rack is on top of the bed now. It is 4" tubing. I was considering cutting it from the bed and then mount to the front of bed rather than on top.
Flat belt supplier
Started by Ikemonroe on Sawmills and Milling
Last post May 19, 2015, 05:21:12 PM
by Ikemonroe
band saw blade supplier troubles, need new supplier help
Started by low_48 on Sawmills and Milling
Last post April 13, 2007, 06:23:17 PM
by ladylake
Log Length Supplier??
Started by heat maker on Firewood and Wood Heating
Last post March 12, 2014, 08:47:29 AM
by heat maker
log railing supplier
Started by solodan on Timber Framing/Log construction
Last post May 07, 2007, 02:27:03 AM
by solodan
