Arborwear
Author Topic: Big dead red oak  (Read 1179 times)
Offline Kwill
  • Cedar cutter
Big dead red oak
« on: December 30, 2017, 08:49:23 PM »
I found a big dead red oak a couple days ago while walking through my woods. Problem was to get to it I would have to cut a path to get the tractor to it. It was on a hillside where I couldn't easily get my log arch to pick it up. It was leaning up hill and I was hoping to get it to fall down the hill. It ended up falling across the hill sideways. It actually worked out good cause I was able to cut it and the pieces rolled down the hill where I could split it. The pieces was so big I had to split it cause I couldn't get it loaded. Here is the tree.
   HAd to cut a path through here
Got the path cut
  Splitting the big pieces
Built my own log arch
In the process of building my sawmill
Offline Kwill
  • Cedar cutter
Re: Big dead red oak
« Reply #1 on: December 30, 2017, 09:14:53 PM »
A few more pics
First load
  2nd load
  Got this left to cut up.
Offline Woodcutter_Mo
« Reply #2 on: December 30, 2017, 10:50:16 PM »
 Looks like it made some nice firewood, that's about my favorite wood to split by hand.
- WoodMizer LT25, Kohler, all manual, old "drag" style WoodMizer sharpener, cat claw single  setter
- Husqvarna 372XP X-Torque/24" bar, 455 Rancher X-Torque/20" bar, 550XP/20" bar, Stihl 024AV/18" Oregon speedcut
- Kioti DK45, '92 Dodge Cummins with Cannonball  bed, '07 Honda Rancher
Offline Kwill
  • Cedar cutter
« Reply #3 on: December 30, 2017, 11:33:04 PM »
I've split p!enty of it by hand. Glad I got my splitter finished so I don't have to anymore
Online samandothers
« Reply #4 on: December 31, 2017, 11:04:18 AM »
I like the tractor and dog carrier
Offline Kwill
  • Cedar cutter
« Reply #5 on: December 31, 2017, 12:04:30 PM »
Yeah me and Mollie dog couldn't do without the old 8n
Offline Al_Smith
« Reply #6 on: December 31, 2017, 01:21:39 PM »
You would be surprised how much that little Ford can pull if you could get the weight of the log on the three point hitch .More weight it fact than what you can steer .
Offline 1countryboy
« Reply #7 on: January 01, 2018, 01:10:55 PM »
that little ford is nice, But be extremely careful.   Fords flip over very fast.  I have put two neighbors fords back on 4 wheels.   They were both very lucky.
Ohio Certified Tree Farm
Offline thecfarm
« Reply #8 on: January 01, 2018, 01:53:52 PM »
Have to respect any piece of equipment. Thos Fords will pull,but only pull so much. When the front comes up step on that clutch,they will come back down. Or at least the one that I was around for 40 years always did.
Offline Kwill
  • Cedar cutter
« Reply #9 on: January 01, 2018, 03:29:14 PM »
I need to fluid the back tires as I have traction issues sometimes. Had to put my box blade on too get my trailer pulled up the hill. I don't skid logs with it. Pull trees down when they get hung up though. I don't use the 3 point for pulling. I have lower drawbar for that.
Offline thecfarm
« Reply #10 on: January 01, 2018, 04:13:37 PM »
Fluid will help,A LOT.  I myself prefer fluid in the tires,not a weight box. The weight is under you,where's it needed,not 3 feet behind you up in the air 2 feet.
But a trailer behind that tractor will hold it back too. I can remember having the front wheel of the tractor come up against a stump than the real wheel of the trailer up against a rock and than the real wheel would spin and there would be a good size root. That would stop my Father. Than he would have to back up and set over and all would be good.
He use to use it in the winter a little bit,until snow got too deep to get the wood out.
He only got that thing stuck once. He was mowing the meadow and an old dead snag got floated in. He straddled that,picked up the real wheels and he was stuck. Took alot of blocking and jacking but we got it. That old dead snag went for a ride too.  :D
Offline Kwill
  • Cedar cutter
« Reply #11 on: January 01, 2018, 05:05:43 PM »
 I've got the valve to put it in. Was going to go with washer fluid. Its not as corrosive. I need tonget it done. Nothing worse than making it half way up a hill and spinning out then having to try and back down the hill.
Offline gspren
« Reply #12 on: January 02, 2018, 07:46:18 PM »
  Do you have a hitch on the back of the scraper box? I've been thinking about adding one to mine.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #13 on: January 02, 2018, 08:04:01 PM »
I've added receiver hitches to my box blade and winch. Very handy.
Offline Kwill
  • Cedar cutter
« Reply #14 on: January 02, 2018, 08:12:18 PM »
no I had the box blade on the quick hitch
Offline gspren
« Reply #15 on: January 03, 2018, 09:23:08 AM »
But was the trailer hitched to the box blade?
Offline Kwill
  • Cedar cutter
« Reply #16 on: January 03, 2018, 02:21:08 PM »
no the trailer was on the drawbar
Online samandothers
« Reply #17 on: January 03, 2018, 05:13:25 PM »
Dads 8n would be light in the front with the disc or hay rake.  The steering brakes were real handy.  My brother now has the tractor.  It does need some work!
A pet, like a dead one
Started by biziedizie on General Board
Last post October 07, 2003, 08:57:59 PM
by Don P
dead red oak
Started by xlogger on General Board
Last post September 28, 2013, 05:03:59 PM
by xlogger
I ain't dead,
Started by DanG on General Board
Last post June 19, 2004, 07:05:02 AM
by L. Wakefield
Dead Ash Value?
Started by martyinmi on General Board
Last post December 11, 2011, 09:40:50 AM
by zopi
