TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: Home made bandsawmill questions  (Read 536 times)
Offline Michael Surman
  • Member*
« on: January 01, 2018, 07:15:15 PM »
Hi Iíve just signed on to the forestry forum to ask some questions about my saw mill
I purchased it as a locally built resaw for sawing shake bolts at a mill in Cowichan on Vancouver island. It has a 10 horse electric motor, and a manual hydrolic 3 ton tensioner. It worked great for pushing through small cedar loggs
I decided to increase what I could do with it by turning it into a mill, so Iíve widened it turned it horizontally and made a 20 ft track. It works pretty well, Iím not into making 2+ 4s just want to be able to make some furniture useing some of the wood I often get given as a tree climber. The question is Iíve been useing this withought guides, the blade does run true for cedar as long as I keep about 2500 lbs of pressure on it, but for harder woods when it hits a knot the blade often dives. I donít mind putting on a new blade, but would it help if I put on some guides, I didnít want to buy them if I donít have too, any advice please
Offline KirkD
Re: Home made bandsawmill questions
« Reply #1 on: January 02, 2018, 03:59:25 PM »
Welcome to the forum! I am not an expert but I think most all band mills run a guide and the reason is to keep it from cutting wavy and also you can have premature band breakage if you don't. Both Cook's and Wood-mizer sell assembly's that can be retrofitted on to about any mill.
Wood-mizer LT40HD-G24 Year 1989
Offline DDW_OR
Multitek 1610EZ, TimberKing 2000 & Talon Sharpener,
Made it home
Started by WV Sawmiller on General Board
Last post September 21, 2018, 10:41:47 PM
by Don P
made it home
Started by Wife on Sawmills and Milling
Last post October 29, 2004, 01:28:20 AM
by TN_man
Home made sawdust fan
Started by dail_h on General Board
Last post September 16, 2005, 11:07:55 AM
by OneWithWood
home made rollers
Started by lyle niemi on Sawmills and Milling
Last post April 19, 2012, 08:40:12 AM
by Jemclimber
