Dust collector vent hood design?
Started by SawyerBrown, April 11, 2016, 06:47:39 AM
SawyerBrown
Just bought a "real" dust collector for my wood shop (to supplement the furnace blower / furnace filters design I have now), and I'm wondering if anyone has suggestions for vent hoods?  Seems like they need to be down relatively close to the machines, but then having enough light might be a problem.  What are you all doing?  (Pictures would be great!!)  Thanks for any and all suggestions!
DDW_OR
Maybe LED lights mounted in the Hood?
remember, the bigger the hood, the bigger the CFM needed.
also add a Cyclone separator to remove the large chunks from the fine dust.
I plan to use a squirrel cage to provide the suction. so here is my plan
Hood > cyclone > large 4'x4'x4' box > Filter > squirrel cage
the 4x4x4 box is to allow the dust to settle out of the air
ozarkgem
Quote from: SawyerBrown on April 11, 2016, 06:47:39 AM
Are you talking about a hood like a grill hood over a stove?  For my small planer I used a floor register from an HVAC store. It is 12# wide. You could use 2 for wider applications. Cheap maybe 5 bucks each. A hood would require a LOT of cfm.
