Stihl 032 high/low settings
Started by matt, June 22, 2004, 01:39:41 AM
matt
Hi, can anyone tell me the number of screws out to set the high and low adjustments on the 032 Farm Boss, circa 1988
Much appreciated. Matt
Hawkin50
Hi mat.Try turning the h and low screws in gently till they seat.thumb and finger tight.Try 1@1/4 turns out to start.Low mix screw like 1 turn.high speed likely 1 to 1.1/4.Then adjust the idle speed just under chain engagement.Best of luck.Hawkin50.
Rocky_J
Bookmark this page, it is yer handy-dandy reference for adjusting carbs.  :)
http://www.madsens1.com/sawtune.htm
 8)
dozerdan
Hi
 Madsen's does have an excellent site for adjusting your carb.
 Stihl produced the 1113 series of saws from 1970-1985 only.
 First was the 030 in that line up built from
1970-1971
Next was the 031 built from
1971-1982
The 032 was built from
1978-1985
If you purchased the saw in 1988, it must have been on the dealers shelf for a few years.
Later
Dan
Danny Henry
Central Pa.
Home of the Original Power Ported Saws
570 658 6232
dozerdan@sunlink.net or
dozerdan@nmax.net
matt
Thanks for replys, much appreciated. Actually bought saw used in 88 and it has been going strong ever since.
Thank again. Matt
