Depth gauge removal?
Started by Satamax, August 31, 2011, 12:39:00 AM
Satamax
Hi everybody!
This is a daft question.  I see thoses guys with chain mills strugle with the slow cutting of such contraptions. Would taking out the depth gauges on a new chain speed up the process at all? I'm not talking about the power it takes. Assume, there's infinite power on hand.
Thanks a lot.
Max.
maple flats
I'm just guessing but my thought is that you would plug the chain by having too much volume in chip for the available space. You might get away with going slightly heavy but I'll bet there is a max that would work before things went south real quick.
John Mc
It would probably interfere with the motion the chain makes through the cut. The cutting tooth actually "porpoises" through the cutting of each chip, and the proper depth gauge height helps to set up that motion.
Even if you have the power to drive it, the drive train is going to take quite a pounding from this. Also, the cutters will wear more quickly, and may be more prone to snapping off.
lumberjack48
You can not cut the rakers off, on less your going to cut ice.
You need a ripping chain, with every different wood your ripping , soft to hardwood, you change the cutter angle and raker depth, and make sure your getting proper oil to the bar.
I never did much ripping, theres guys on here that have a lot of experience on this topic.
Al_Smith
If you get to fooling around grinding the rakers off all you'll do is make a jerky chain .As such first off all it will beat the tar out of the sawyer. In addition beat the dickens out of the bar,clutch, rim sprocket ,bearings and seals and could break a crankshaft if you have enough power . Better off to just leave well enough alone .
