formula for est. bdf
Started by leggs, June 13, 2005, 11:25:00 AM
leggs
                   can anyone help with a formula for estimating bdf in a log?   thanks
https://forestryforum.com/board/index.php?action=toolbox
There are almost as many formulas for estimating volume as there are types of trees.
Bibbyman
The mathematical formula is just the start of the process.  It just takes in to input the diameter and length.
Logs of the same diameter and length may not scale the same when defects are taken into consideration and deductions made for same.
Here is a discussion we've had on the topic of grading and scaling logs.
Grade the log - sweep, crook, shell, rot, etc.
Sawing since '94
sparks
Here is a printable version if you like.
\"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.\" Abraham Lincoln
Here are few more tables.
More...
Bibbyman
  smiley_contract_point smiley_crying smiley_headscratch smiley_goofy_face smiley_dizzy
My table is too full!
Sawing since '94
