ID Help
Started by dgdrls, April 18, 2012, 09:11:26 PM
dgdrls
Helping to cut some tree's for a Moto-X track.
Will save some hard maple for the mill,
but am stumped on these logs, I have an idea, but not certain
These are in Central NY.
DGDrls
Okrafarmer
I'll be interested to see what the foresters and others say. My first glance at the first picture, I thought black cherry, but then it didn't really look like that, and the farther down the pictures I went, the more it looked like some kind of oak to me.
Now selling Logrite tools!
John Mc
It does not look like black cherry bark to me.
Okrafarmer
Quote from: John Mc on April 18, 2012, 09:58:15 PM
Yes, after my first glance, it didn't to me either.
celliott
How about a picture of the bud and the twig? Often times that can be much more helpful in ID'ing a tree than the bark\cross section.
Chris Elliott
Clark 666C cable skidder
265rx clearing saw
dgdrls
I'll see if I can get some additional info/ buds, twigs,
DGDrls
Ron Wenrich
Elm.  That's an ID of what the wood looks like.  Black cherry doesn't have the heavy growth rings.  Neither does hickory.
When I took my first dendro class, the prof used to point out bark, tree form, buds and leaves.  We used to ID trees using the leaves.  Then came October and leaf drop.  So, we learned to ID trees using tree form and bark.
That worked pretty good until I got my first job in a sawmill.  I was the log scaler.  No more tree form, just bark and wood.  Now, as a sawyer, I don't even get the bark.
ArborJake
 The bark on that tree looks alot like Native Red Maple that grow's around here but not shure about the heart?
thick and thin lumber company. qaulity manufacturer of saw dust and slab wood.
It is red hickory, Carya ovalis.  Some consider it a scaly barked variety of pignut hickory, Carya glabra.
Okrafarmer
Quote from: WDH on April 19, 2012, 09:05:35 AM
Quote from: Ron Wenrich on April 19, 2012, 06:50:09 AM
Uh-oh.  ???
The thickness and color of the inner bark still lead me to red hickory, although Ron has a lot more experience with logs in that area of the country.  Here is how to solve the problem:
If it is elm, then the latewood pores will be arranged in distinct wavy bands.  If it is hickory, the parenchyma in the latewood will be apotracheal, that is, it is not singularly associated with the latewood pores, but is more random in distribution, but the latewood pores are more scattered and never arranged in wavy bands.
So, to settle this question, a close up pic of the end grain will tell the tale.  It is all about having the right information  :).  Sometimes a pic of only one feature is not enough information to be definitive about an ID.
Dodgy Loner
I believe that is in a hickory as well. The bark is just way to thick to be an elm. I would call it a pignut hickory, because I have seen too much variation between red and pignut hickories to separate the two as species. I think it's just one species with a high degree of variability.
Ron Wenrich
What's it smell like?
LeeB
My first thought was hickory, but I'm by no means an expert.
I was thinking something related to walnuts and hickories. The only elm up my way is American, which is a white elm. So I do not see the other elms in the south.
Dodgy,
I learned it as red hickory back in the dark ages.  Since then, it has been considered a variety of pignut hickory.  I have seen a lot of it with 7 leaflets whereas the tried and true tight-barked pignut usually has 5 leaflets.  I guess pignut hickory has many faces.
dgdrls
OK guys here is a little more ammo,
Also, the wood seems very stringy/fibrous in the longitudinal section,
Tree was a triple stem.
DGDrls
Okrafarmer
Probably all descended from the same ancestors, just like Chihuahuas and Great Danes both come from wolves.
Quote from: WDH on April 19, 2012, 09:15:05 PM
Dodgy,
Definitely hickory.
Yes I would agree. And as a side note, that upper bark there has traits of young trees and upper limb bark of butternut (probably walnut to). The buds aren't as big, but sure can see traits. ;D
dgdrls
Thank you gentlemen,
Ron W, my Conservation class in H.S. was also taught
the same way with winter tree I.D.
DGDrls
Dodgy Loner
Oh yeah, those twigs are 100% a confirmation. You've got hickory. That second bark pic sure looks like a pure pignut, but as WDH noted, many dendrologists would say that the bark in the first pic is more typical of red hickory. Hence my propensity to lump them all together! :D
doctorb
As an interested bystander to all this tree knowledge, I know how to tell the difference between hickory and elm.  Cut a 20" round and swing a splitting maul at it.  If it splits, it's hickory.  If the maul bounces off, it's elm.  Knew I could help! ;)
Dodgy Loner
Haha, that's one indicator :). Just to complicate matters, though, I've had some hickory firewood that gave a hydraulic splitter a workout!
Okrafarmer
Quote from: Dodgy Loner on April 20, 2012, 03:31:50 PM
Yes, that is my experience too. They are both tough splitters.
Quote from: doctorb on April 20, 2012, 02:50:32 PM
I'd say, if it splits it is oak. :)
hackberry jake
I've had straight grained hickory fly apart like red oak, but I've also had hickory that went in the "campfire wood" pile because it wouldn't split if it were holding a pair of aces. The hardest wood to split has got to be magics favorite, sweetgum. If anybody ever finds a use for that junk they'll be rich. Looks like hickory to me ass well, it definately wasn't a fast grower.
Had one recent rock maple that gave one guy (me) with a 5 lb splitting maul, 10 lb post maul and a wood splitter a work out to. :D I busted the neighbor's home made split'n maul in two pieces. Broke at the weld and in the iron handle (sandwiched by two wood halves). I went to town and got a Garant splitting maul and finished up. That was one tough old brute (maple). She's firewood now, 2 cords. :D Had to chainsaw some grooves in the top of the blocks to make any headway.
doctorb
My experience with hickory is even less than my experience with elm, which I have tried to avoid.  I had 2 hickory tree I turned into firewood, both about 14 - 16 " in diameter.  It was harder to split than oak, but I managed OK. I would rather roll elm down the back hill.  Sorry about the hijack of this thread!
I had several rounds between 24-36" across that I had to bust up to get onto the splitter. :D
Doc,
You should write a tree ID book  :D.  I like things simple  ;D.
Okrafarmer
I had a fellow down here tell me, if you want to tell the difference between ash and hickory, start your saw. If you go to cut it and the saw bounces back, it's hickory.
Ash's parenchyma is paratrachael in the latewood (OK David, jump on this  :D).  It is all in the parenchyma  :).
Okrafarmer
Quote from: WDH on April 20, 2012, 09:12:40 PM
??? Sounds like more skin diseases to me....
dgdrls
Get the Brown soap out  :D
Thanks again gentlemen,
the help and humor is much appreciated.
DGDrls
