cool air
Started by woodmills1, October 20, 2016, 09:10:46 PM
woodmills1
tonight my furnace was blowing cool air into the house.  The fire was going well, the circulator pump is running.  The pipes at the heat exchanger were hot on the in side but cool on the out.  I cracked the connection on the out and closed the valve and water was coming out, so I took the out connection off and the whole exchanger got hot.  I reconnected and when I turned on the furnace fan the exchanger got cool again.  So, bad circulater, clogged exchanger or clogged pex?  Thanks in advance.
Bill Saf
is it a new unit or have you had for some time? if the pump is moving water I would say a air lock at your heat coil if it worked when you shut it down for summer and not now I would say air.
woodmills1
13 years with this set up and was doing OK since middle September, just today cool air.  got water through heat exchanger just no reference as to how much it should flow
Bill Saf
so its been running as of sep and ok and today no heat that takes air lock out of it Id say pump.
air lock is common and the first thing I look for.
woodmills1
thanks for the input, it was the circulator.  The plastic impellers had shredded, so that is why the motor could still turn, leading to my confusion.  Taco 009 bought off the shelf from Webb plumbing supply.  Problem solved by noon.  That pump and motor turned for 13 years of 24 7.  Is that like 25 billion revolutions?  QC to engineering, we had faliure at 25 billion revolutions. :P
LAZERDAN
woodmill 1
     Either you are a math wiz or a good guesser.  1,708.200.000 revolutions per year x 13 years.  My calculator does not go that high, but i think your really close.  Had the same thing happen to mine after 7 years.     Lazerdan
woodmills1
 Ldan, I used scientific notation.  I started college before electronic calculators were inexpensive enough for ordinary students.  Used a slide rule till 1971. so, yours would be 1.7 x 10 to the ninth power  multiplied by 1.3 x 10.  1.7 times 1.3 is 2.21  and ten times ten to the ninth is ten to the tenth giving 22 billion.
LAZERDAN
You had me at 25 billion !         Awesome               Lazerdan
woodmills1
10 times 10 is 100      1 times 1 is 1      2 zeros makes it 100
