firewood storage
Started by r.man, September 28, 2013, 07:15:15 PM
r.man
I am constantly impressed with the different ways people solve problems. This video shows a very innovative way to somewhat ease the day to day work spent loading a wood boiler.http://www.youtube.com/watch?v=-CZfnxwJBwc
JohnG28
That's quite a sharp little idea.
sam-tip
I like it.  Good work.  I would be afraid of burning the roof down. I have flames and back drafts coming out of my boiler door.   Well sealed gasser.   I want a roof but think I should go with metal.
Central Boiler E3200 WiFi
Many many ported chainsaws. 201 to 3120
TM log splitter pro30 6 way head
D&L 1020 swing blade sawmill for slabbing
Timberking 1220
jackel440
This is a great idea,I was considering something along the same lines.I had planned to use my skidsteer also.I also thought abount some kind of conveyor system to bring the stacks forward too.
DeerMeadowFarm
I am in the early planning stages of a similar set-up. I have 30' of C-channel trailer frame welded 7' apart. I plan to make racks that'll hold 1 cord. I need to come up with an inexpensive roller/wheel device to use at the 4 corners of each rack. I plan to pull mine forward using a 120V winch
Philbert
Nice system.  Looks well made.
But if he's got the skid steer loader, he could just use forks and palletized / caged firewood to bring stuff up to the point of use. That way he could select wood to burn (e.g. species or age), rather than having to follow a sequence, store wood farther away (fire comment above), etc.
The winch idea is pretty cool too, if you can get a good deal on track and rollers.
Philbert
I thought about 2 trailers.Load up 2 trailers, use one and having one all loaded and ready to go. Than when one is empty,pull it out and re load it.Most of us don't have a skid steer to push with.  :( My trailers will hold about a ½ cord to ¾. I have used it a few times. I take it out in the woods and load it up and then leave it by the OWB.
jamesconley1962
Quote from: thecfarm on October 31, 2013, 03:55:43 PM
That's what I do and it works good.
sam-tip
If you added walls or an insulated tarp you could blow heat through it and dry your wood in days.  Fresh wood on one end and dry on the other.
Timberking 1220
Yatt
288 XP Lite
372XPG
562XP
357XP
550XPG
346XP
Dolmar 7900
028 Super totally rebuilt and ported
Speeco 28ton splitter
Silvey 510, Oregon 511AX & Tecomec grinder
AnthonyW
I too would not have the roof that close to the boiler.
I would also use wheels on the railroad tracks, perhaps old wheelbarrow rims with no tires on them.
'97 Wood-Mizer LT25 All Manual with 15HP Kohler
DeerMeadowFarm
Well over the long holiday weekend I picked up the sections of trailer. Man, that was a wide, scary load to bring home!  sail_smiley
Anyway; here I am unloading them.
DeerMeadowFarm
Here is the thought/plan. The width between rails is approx. 7'. I am thinking of making pallets 8' wide by 2' deep and stacking 4' high. This will giive me 1/2 cord per pallet. This way I can pick up one pallet with the forks on my loader and another on forks on the 3-point allowing me to move 1 cord out of the woods at a time.
I'll need 4 wheels per pallet though which is going to add up quick! I'm thinking of some simple metal rollers like they use on dumpster roll-offs but smaller. Maybe make some out of 2" pipe with "washers" welded on both ends and using a 1/2" grade 8 bolt for an axle? Attach to the pallets using angle....?
Thoughts? Suggestions?
8 feet wide coming out of my woods road would be a problem. Too many rocks and too many trees I want to keep.
I suppose these will have sides all the way around? Just asking because the wood might try to fall off coming out of the woods. On my trailer I just about have to bind it down when coming out of the woods. My woods are rough.
DeerMeadowFarm
I'm figuring some side posts with ratchet strap along the top for transport. My tractor's bucket is 6' wide; what's another foot on each side? :)
The wood lot I bought was logged maybe 40 years ago (guestimate) and there are main trails from the skidder that wouldn't take a ton of work to clean up....
Maybe I make the pallet part 4' x 4' each but my frame that goes on the rails is 4' x 8'! Still taking the same amount of wood out each time, but I'll be narrower and I'll need less wheels!
stavebuyer
Some sawmills use well casing or other heavy metal pipe to stack lumber on instead of lumber carts. On clean concrete one man can push a 6000# pack of lumber on the pipes.
North River Energy
Maybe do a test shove of a loaded rack, using UHMWPE (sandwich board) in place of wheels?
I'd be tempted to buy a box store splitter, strip off the running gear, bolt the works to the floor at the far end of the track, and use that to shove the racks toward the boiler.
