Whatcha Sawin' 2019 ???
Started by Magicman, March 08, 2019, 08:46:24 AM
terrifictimbersllc
I dont know how you do it.
Darrel
Magicman, you ain't 'spoked to be doin' dat stuff!  Glad that you're able to deal with more sand tomorrow!
1992 LT40HD
doc henderson
that is funny, 5 cm is about 2 inches, glad you got your sense of humor.  you trimmed the wrong "limb"!!!  glad you were ok.  I am sure pat knows how to sew.  you should of spent a little more time on your trip!  best regards sir.
Peter Drouin
Good luck to you hope you can keep the sand out of the cut.
A&P saw Mill LLC.
License NH softwood grader.
Sixacresand
I would be more concerned with the 103 than the sand.  I get hot stupid.
Thanks guys, forecast to be a bit cooler today.
Chain brake was on and the saw "kicked back", still no excuse for carelessness.
Quote from: Andries on August 13, 2019, 11:40:27 PMHoooooo Boy, it might've been big boy hot - but filling your boot with the red stuff had to raise your temperature a bit too!
Funny you should say that.  I didn't have a water hose so I washed my boot out in the hotel bath tub and dried it with the hair drier.  Had to do some serious cleaning it up so they wouldn't think that there had been a chainsaw massacre.  :o
Monday, I got too hot and saw the bear.  Heat index was 109.  It is dangerously hot here in Georgia.  Yesterday I had some things to do in town so I took it pretty easy. As you know MM, when you get that hot, bad things can happen like what happened to you.  Every time that I need to saw something quick with the chainsaw and do not use the chaps, that little voice in my right ear says, "UMMM, you better not."
Looks like you will make a little less profit on this job :).
Woodpecker52
Morning work till you can't breathe heat index 115 today, and your clothes are drenched in sweat, shower, change clothes, eat, nap, start again at 3 till dusk, remove clothes  that are sopping wet from sweat, pray for wind, and it rains again so it will be steaming again in the morning.  Oh the joys of living in the south, the only good thing I know from dripping sweat all over is that it drowns the chiggers.
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
Southside
MM you could have just told us the bear got your leg and you fought it off to protect PatD and none of us would have been the wiser for it.  :D
White Oak Meadows
Resonator
Take care of yourself MM, don't be afraid to take a break and sit in the truck with the AC on when its that hot. Missed you at the Pig Roast this year, (though it was kind of like you were there!) ;) ;D
Darrel
Quote from: Woodpecker52 on August 14, 2019, 12:10:10 PM
I had never experienced anything like what you're talking about until I landed in Japan. The heat index was 112° and the air was so wet in Tokyo that you could see it like fog. Everything you touched felt sticky. Right now there's a typhoon to the south sending clouds, rain, wind and cooling. Daughter and family make it all worth while, but you all can have this wet heat.
1992 LT40HD
redbeard
Hope you had a better day today than yesterday, that's a good size bite out of your shin.
Ouch!
You might still have sea legs going on with all the sailing you did out west.
Take care be safe!
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
Bruno of NH
MM please watch yourself in the heat.
Also everyone else
We are getting another dose of the heat and humidity coming in on Saturday night till next Tuesday.
The leg looks to be in good shape for the shape that it is in.  I believe that it will be OK.
It was brutally hot again today.  I did eat a few snacks and a banana and kept swigging on the water bottle the entire day.  More tomorrow.  I wish that I could work early and late, but that won't work with the tailgunner.   :-\
Dirt, what dirt, I don't see any dirt.   ::)
The forwarder dumping another load of "logs" for the "skidder" to haul to the sawmill.
The skidder got a few of them up the hill and ready to be bucked.
A whack of Pecker Poles ready for me to buck.  :-X
The customer bought 10 more acres of timbered land last week, so maybe he will have enough logs to supply his need.  I am sure that I will be here for a couple more weeks.
Banjo picker
Lynn You are definitely tougher than me.  I have and order laying on the ground by the mill.  That I haven't touched in 2 weeks ... and got a call from a customer Sat. evening ....went and looked at them Sunday and told him I will get to them when it cools off a bit.  I cut and order for a commercial customer a few days ago and thats all i plan to do untill September.  Right now we are renovating a rental that got trashed....at least the ac is now working.  Got about 2 or 3 more days in there.  We got 3 of them and if they wern't so close to the house I would sell them all.  Banjo
TimW
MM,
   Glad to see you are back in your sandbox.  Don't you have an umbrella on your seat?
Just what is a pecker pole?
In the heat of the summer, I change clothes 4 times a day with two-three wash off baths in between.  Atopic Dermatitis likes wet shirts.  I don't like either.
hugs,  Brandi
Need to lay a few logs on the ground to dumps logs onto to keep them out of the dirt. :(
But do all that digging at my place I would have rocks to put logs onto. :o   What dirt?
Quote from: Bindian on August 14, 2019, 11:21:20 PMDon't you have an umbrella on your seat? Just what is a pecker pole?
Yup, I'm under an umbrella when I am sawing but all of the other time (majority) I am not.
To me pecker poles are long skinny logs/trees that won't make lumber, but we do it anyway.  Thankfully all of these will be 4"X 6" timbers.
WDH, so far all Oak.
Here is a typical example of what I call a pecker pole.
This thing was barely 12" at ground level.  I bucked it into four 11' "logs" that made 4"X 6" timbers.
My today was a strange deal.  Hot Yes, but it got more interesting at 3:00.  The dirt moving crew couldn't/wouldn't/didn't do what the builder wanted done so he sent the whole crew home.  Well my tail gunner was riding with one because he has no driver's license so he when home too.
No, I didn't charge for the two hours that I missed because I was glad to quit.  smiley_sweat_drop smiley_sun
I will only work until noon tomorrow, shut it down, and make the 4½ hour drive home.  I'll be back and ready to saw Monday morning.  It's sorta iffy whether I'll get all of his downed trees done next week.  ???
TimW
Quote from: Magicman on August 15, 2019, 08:21:44 PM
Looks like pecker poles could be telephone poles also.  How was the wound today in the heat?
hugs,   Brandi
petefrom bearswamp
Son and I sawed 2x10x12 Hemlock yesterday along with a few 2x8 and 2x6s
Weighed a random one
Weighed 92 pounds no wonder my tail man gets tired.
Only have to lift the first one in a tier then can slide them but still heavy work.
calculate that 4 tiers weighs around 1800, makes the front tires on the Kubota squat a little.
I only saw half days now.
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
That heavy stuff will work the tail off of a tailgunner Pete.
I am doing sorta OK Brandi.  No bother with the wound, but this heat is brutal.
I am marking and bucking this morning, but I have not seen my tailgunner yet.  This may be a short day.
