Anyone ever had this break on their Wood-Mizer? Also, what's the name for it?
Started by RPowers, January 19, 2019, 11:00:41 PM
RPowers
I took my lower drive belt guards off to check the belt tension as I have about 20 hours on a new belt, and this fell out when I pulled the covers.
How it didn't get into and break anything important while the mill was running I don't know. I need to order a new one but have no idea what it is called and where to find it in the parts lists. Also, what is the proper way to position this on the mill in relation to the drive belt? Thanks in advance!
Ryan
2013 Woodmizer LT28G25 (sold 2016)
2015 Woodmizer LT50HDD47
Brad_bb
What year and model mill?  Do you have the manual that has the exploded parts diagrams?
Southside
I am assuming that is from your 50?  If your mill is registered with Wood-Mizer go to your account and you can get into the exploded parts by category.  Go to the head section, I have to think something will match up in the diagram so you can get the right answers.
White Oak Meadows
RPowers
It is  a 2015 LT50. I've browsed all the exploded head diagrams and didn't see it. Doesn't mean it isn't hidden there somewhere I just havent found it yet.
Southside
White Oak Meadows
terrifictimbersllc
Mine is called a "clutch enhancement weldment" and is listed in the parts finder engine>d42> drive assembly, $22. Never had it break.
p.s. in your parts manuals, would probably be shown in the engine supplement booklet where the belt is shown.
moosehunter
It is a belt guard. Mounts so that that round end is just off the drive belt below your drive pulley.  I believe that it just keeps the belt from flopping too much during engagement and release.
mh
Higher than my expectations
It is positioned just below the engine drive pulley and adjusted so that it keeps the belt from flopping during disengagement and still allowing the belt to creep.  This disengaged creeping is necessary to keep the belt from getting hot/burning against the turning drive pulley.
Chuck White
In my "LT40" manual it says position it so that there is 1/8 inch clearance between it and the drive belt, when the drive belt is tensioned!
Sixacresand
John Bartley
Quote from: Sixacresand on January 20, 2019, 09:25:09 AM
Can it be welded?
Yes it can be welded.
Belt guides are not made of any special metal and are not heat treated.  The key thing is the alignment. that affects operation and belt life span. Follow the instructions in the manual.
Kioti DK35HSE w/loader & forks
Champion 25hp band mill, 20' bed
Stihl MS361
Stihl 026
RPowers
MartyParsons
Yes weld it. Not real pricey .
The bolt will need to slide in the grove.
Marty
