Stihl 039 No Bar Oil
Started by Rhodemont, March 30, 2019, 06:39:48 AM
Rhodemont
Have a 039 my elderly neighbor gave me long time ago because he had hard time starting it.  I do find it tough to start but it has been running and cutting great once it gets going.  Last week bar went dry and started to heat.  Had plenty of bar oil.  I took bar and chain off, blew off all saw dustg which was kinda dry when usually oiled up.  put a fine wire in the oil outlet hole to make sure no debris.  Did get a little drip of oil come out so figure that was the issue.  Ran it yesterday, it was still dry.  Where do I go from here?
Woodmizer LT35HD    JD4720 with Norse350 winch
Stihl 362, 039, Echo CS-2511T,  CS-361P and now a CSA 300 C-O
dougand3
Probably the nylon worm gear is worn. It has the "spring" with Z shaped rod that fits in sprocket notch. Possible that spring is loose on nylon gear and not turning gear. Take sprocket off and see if spring turns gear. Gotta pull clutch for further inspection. Easy to replace gear after clutch off.
Rhodemont
Will do.  Feel like a surgeon going in.
