Jonsered Cs2255 Looses aolot of power at full throtle
Started by Logger615, June 21, 2015, 10:53:55 AM
Logger615
While cutting yesterday noticed I started loosing full throttle as I was cutting. Fully warmed up if I try to give it full throttle it bogs down and dies. I can only get to half throttle before it starts loosing power in a big way.  Any ideas?
dougand3
Sounds like a fuel delivery problem. Some ideas...Fuel tank vent partially clogged - does it run better with cap loose? Fuel filter/pickup partially clogged? Fuel line hard or too soft and collapsing? Carb screen partially clogged? Carb diaphragms getting stiff? H screw too lean?
ladylake
A lot of good points above, plus check the muffler screen, clogged they will have no power.  Steve
Logger615
Thanks guys, I was figuring some sort of fuel issue. Small engines have never been my strong suit didn't really know where to start, got a few things to check and rule out now!!
Jason
lumberjack48
 Open the low jet about 1/8 th of a turn [ turn it counter clock wise]
Spike60
Is this new and did you buy it at tractor supply? Was it set up and adjusted for you? They won't run right out of the box.
Husqvarna-Jonsered
Ashokan Turf and Timber
845-657-6395
