Cedar for canoe
Started by kenfrommaine, July 04, 2017, 09:06:56 PM
kenfrommaine
Hi
I have some nice white cedar that i would like to saw out and turn into cedar strip canoes over the winter. Question is how thick should I cut the boards so that they dry enough to use this winter?   Going to be fiber glass over the cedar strips if that makes a difference. Thanks for you thoughts on this.
hersnsh#590
Ken:  If you're going to "bead and cove" the strips, the router bit  you use must be considered.  I seem to recall my boards were 1" thick, and I planed them to 3/4" thick, then ripped them to 1/4" for the strips.  Gil Gilpatrick's book is a good source.
Dale
TK 1600, small sugaring operation, a bench full of J'reds, a tired ford 1710, new to us JD 5065e, 2 Honda 4 whlrs, a Can-Am 580 on tracks, and a very understanding wife.
69bronco
I've done several strippers over the years, my opinion is that anything much wider than 3/4 is a pain to bend.I cut my stock at 1" and plane to 3/4 then rip on table or band saw to 1/4". No need to smooth as you will be doing plenty of scraping/sanding later.
