Proper stacking and drying of lumber outdoors.
Started by Aeneas61, February 17, 2016, 03:54:41 PM
Aeneas61
Hello all,
Very new to sawmilling my own lumber, have a question;
I will be sawing and air drying lumber in the next week. What is the best way to stack and prepare wood for outdoor air drying?
My local sawmill has stacks of wood stacked outdoors, stickered, but with no protection over top, much has sat this way for years and seems fine, is this only because it is kiln dried first? Do I need to sticker it and cover with metal roofing or a tarp?
Welcome all experiences.
Josh
OlJarhead
Aeneas?  As in WA State?  If so we're neighbors.
I stack and sticker all my lumber and then cover it with a tarp but try not to cover the sides so air can move through the stack -- the tarp keeps the rain off so it won't rot the wood.
Can't say about wood laying about for years but to me it would get checked, warped and rotted so no way I'd do that.
If the stacks of lumber have been un-covered for years, then the top layers will be rotted and on down through the center of the stack. Kiln drying won't protect from that rot.
As said, cover the top with something waterproof. Add low grade boards to the top for weight if nothing else, but protect from becoming wet.
Need a good level foundation. I need to take mine own advice.  ::)
GeneWengert-WoodDoc
Check AIR DRYING of LUMBER...it is on the Internet
YellowHammer
Lots of good tips for air drying are in publications on the web and in this Forum.  However, a few notables are
Flat ground.
Stickers every 2 foot or less
Covered area or covered stacks
Wood stacked as high as possible for weight
Dry spot with good breeze
Sides open to allow airflow
Stacks 18 inches apart or more
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Use quality stickers.  That means dry and uniform.
OlJarhead
On my property I level some ground with my box blade and put pallets down for a base, then sticker, stack and sticker until it's about 4 feet tall.  Then sticker the top, add cover and weight it down.
Peter Drouin
This works for me.
But the goat has a better place for wood. Maybe he can get some pics for us. :D :D
A&P saw Mill LLC.
License NH softwood grader.
OlJarhead
Some day!  Some day!  But for now I'm happy just getting the mill upgrade!
Peter Drouin
With the new mill you will buildings all over the place soon. :D :D :D :D
A&P saw Mill LLC.
