Need help with Woodmizer hyd
Started by Plowboy, August 29, 2017, 07:29:57 PM
Plowboy
I updated the valve stack on my LT30, now the turner will come up before the backstops are fully up. Can adjust the sequencing valves to correct this? I can put a stick in the turner and then the backstops will come before the turner.
MartyParsons
Hello,
   I am pretty sure the priority valve is not adjustable. Something binding on the side supports? It should work the side supports until the pressure increases or dead heads ( resistance) then the turner should come up. Sounds like you understand.
I have seen air cause these priority valves work strange. I have also seen dirt in the valves or even some thread tape. If you dissemble the valve watch out for the screen and the spring. I have one somewhere in the shop. It went ping and I never did find it.  :-\
Marty
Plowboy
Thanks Marty, I'll have to check a few things now.
