Re-sawing pressure treated poles or timbers.
Started by Dave Shepard, December 20, 2012, 07:44:38 PM
Dave Shepard
Anyone do this? I've got one big pole to re-saw, and I think it's SYP. 85' and 28" at the butt. I haven't seen it, but we're supposed to cut it down into shorter logs and make some dimensional lumber out of it. I want to saw an 85' 12"x12", but haven't been able to convince anyone it's a good idea, yet. ;D
I'm not to thrilled about sawing PT, but I do have a wireless remote, so I might have to step back a couple hundred feet and give it a shot.
Kansas
Two things. It cuts really hard. Second, that pressure treatment doesn't go in that far. If your plan is to use pressure treated  lumber, it won't work. If its to use for rafters or such for a barn, it will. If you are portable, get the wind at your back. Probably the 4% blade if you run woodmizer.
VictorH
It's probably poisonous as well so wear a mask if you don't normally.
A FF search will find several threads on sawing PT utility poles.  Some recent.
GeneWengert-WoodDoc
It depends which chemical was used for treating.  If CCA, then the dust, sawdust and scraps are extremely dangerous to you and the environment.  At the least, collect the sawdust and dispose of it in a landfill.  You will create a hazardous site if the sawdust gets on the ground.  It is extremely hazardous if burned.  You need a mask, a shower afterwards immediately, and clothes need to be washed separately.  Arsenic is a major concern, but so is the copper.
GeneWengert-WoodDoc
The chemical used will penetrate through the end grain for perhaps 12" along the length.  Also there will be adequate chemical for 2" of the outside.  Deeper will have lesser amounts.  The reason we need such penetration is that the butt in contact with the ground needs more chemical than the above ground.  Also, Above ground is likely to crack and exposed interior wood, so we do need chemical inside as well as the outer 2".
As the cost of a failure is very high, and replacement cost high as well, utility poles are very well treated, especially the lower sections.
pineywoods
my advice is simple...Don't.... The sawdust is nasty stuff, and handling the lumber will cause not-so-nice problems. Folks that want treated poles sawn into lumber think they are get a bunch of treated lumber on the cheap. WRONG..The center is untreated and will rot quickly. Cutting a pole into fence posts is a maybe idea IF the top of the post is covered with something to keep the water out. Even then then bottom will rot albeit much slower.
drobertson
I have cut a few, and a few more rail ties, as mentioned the treatment is shallow, and the center is often hollowed out.  Not really what the ole boy was looking for when it was all said and done.  I had no reactions I can remember, but then the wife says I don't remember much anyway.  It just is not worth the effort as far as cutting into pieces. Making corner post from them is a different story. Chain saw and a post hole digger is all that is needed.
isawlogs
 I have sawed some once, won't touch it again. It is hard to saw, and the dust off of it is some nasty, you would be well advised to use your station as far away upwind as you can. Then again , someone has to turn it and get some of the dust on there clothe......
   Marcel
Dave Shepard
I think this project has been vetoed.  ;) I don't want to breath or be in contact with the stuff, and I don't want it on the farm. I didn't think the treatment went all the way through anyway. The pole might make a good arm for a trebuchet, however. ;D
isawlogs
 Dave, that is one of the better calls I have read on here in a long time  ;)
   Marcel
Dave Shepard
Yeah, I've been wanting to build a trebuchet for a while now. :)
isawlogs
   Marcel
5quarter
I would pay to see a trebuchet with an 85' throw arm in action.  :o
Blue Harbor Refinishing
drobertson
Not only is the forum great for picking up great information, and useful tips and teqniques, but I am now begining to learn the art of icon simulations.  :snowman: :snowball1: :snowfight1: :rifle: :snowfight1: ::)
steamsawyer
Sawyers discretion advized...
It can be done. I have cut a few for cattle rancher buddys. It usually only amounts to splitting them in half to use for cowpen posts but I have made lumber with them too.
I don't know about other parts of the country but here in Florida they are treated all the way through. Every one I have ever cut was clearly the same green throughout. I have cut creosote poles but I won't do it again, they are black and stickey to the core and they will goo up your saw.
If you do decide to try it, bag the sawdust and dispose of it at a landfill... It is considered hazardous waste. Don't breathe it and don't wear it... After all it is poison.
Here is a little video from last year.  The stuff saws ok but in this video I was dealing with a lot of belt slippage where I couldn't keep the belt tight. I have since installed an idler on the belt.
http://www.youtube.com/watch?v=7XQN9H9nJOE&list=UU7d1hrrieYmf1HNx6ypOVpg&index=12
Alan      :christmas:
J. A. Vance circular sawmill, 52" blade, powered by a 70 HP 9 1/2 x 10 James Leffel portable steam engine.
Inside this tired old mans body is just a little boy that wants to go out and play.
Great minds think alike.....  Does your butt itch too?
Alan Rudd
Steam Punk Extraordinaire.
bill m
Dave, go ahead and make it and I will bring the pumpkins. ;D
rooster 58
I have used pt lumber a good portion of my life to build pole buildings, decks etc. As Doc says, the cca treated material is ;D
