Sawing an oversized log - lessons learned
Started by WV Sawmiller, November 01, 2016, 10:18:43 PM
WV Sawmiller
   I touched on this briefly in Whatcha Sawing but feel it deserves more detail as I bet others have or will encounter this situation.
   My client had an oversized tulip polar log he wanted sawed. By oversized I mean it was bigger than the size limits my mill can handle. My mill is rated for up to a 32" diameter log with a blade pass (max board width) of 23" and this log was approximately 40-42 inches in diameter.
   First we split the log (Not too accurately if the truth be told) with my chainsaw. My MS441 with a 24" bar meant we had to cut from both sides and my cuts did not line up perfectly. The 2 halves were still too big for us to turn with a cant hook once the flat side was on the ground so I quartered the first half and these 2 quarters loaded and sawed easily. The tractor arrived and loaded the remaining half on the mill then left. I loaded the split log on the bed and it landed flat side down. My mill has a claw type turner and clamp. The round side up was still over 23" wide and I could not trim it down from that side. Neither the claw or the clamp would raise the log 90 degrees so the flat side was vertical but could not do so. We even tried chocking and added shims on top of the clamp for extra height. A chain type turner might have worked and the claw would have worked had I had the round side down. Using shims for extra height on the clamp was not safe and did not work. Finally we wrapped a chain around it and parbuckled it upright to a vertical position with a come-along hooked to my truck hitch (used the safety chain loops for better security). That worked and we got the log upright and I was able to clamp and saw it.
   The next log off this same tree was right at the upper size limits for my mill but the hydraulics on the mill worked perfectly loading, turning and clamping on the round log. Just had to Bibby off a little overlooked flare, knots, etc. so the blade guide passed through at max width. I had to rotate the log several times to trim it so the blade would pass through but this worked as designed.
    Lessons I learned from this included:
1. Next time if a log has to be split let the client do so or charge a lot more than I did this time as it took too much time, effort and material (Gas and chainsaw chain).
2. If loading a split log too large to turn with a cant hook make sure the flat side is up so the claw can grab and turn the log and the flat side will rest against the side dogs and/or have MHE available to turn or remove the log from the mill if necessary.
    If anyone else has had similar experiences sawing a large flat sided/split log stretching the limits of your mill and you know of any other techniques I overlooked I'd love to hear them.
Delawhere Jack
You're in the "what was I thinking" club now!  ;D The big ones are definitely a challenge....every time. I won't even consider milling logs over 32" diameter without some sort of support equipment on site -- tractor, bobcat, backhoe or such. The claw turner works great on smaller logs, under 30", but it will have you cussing up a storm when it gets caught under a huge cant for the 4th, 5th, 6th or 7th time in one day. Just had that fun today. Milled three poplar logs 35-40" dia.  You've just got to do what you can with whatever resources you have on hand.
sandsawmill14
i have split in the 100s of them by now i would guess and i charge $15 to split them and then just bdft price for sawing :)
this is a 48" poplar and i had to trim a little off of the top of butt end to get through the mill :)
the chain type turners are not any better you still have to put it on the mill with the round side down ;)
that is a 40" gum log in my profile pic  i use a 28" bar on my 441 if they are bigger than 36-38" and usually the loader will bust them open with only cutting from 1 side :)
WV Sawmiller
SS14,
   You look to be using the same saw I am. $15 is not enough to split one that big IMHO.
sandsawmill14
it works out to about $1 a minute but
these help ;D if i was having to saw both sides i would want more money :)
Andries
sandsawmill - that's pretty darn impressive support equipment!
Thinking that might bill out a tad higher, like maybe $2 per minute?
:D
LT40G25
Ford 545D loader
Stihl chainsaws
Andries
I get asked to mill, not split, some big logs.
LT40G25
Ford 545D loader
Stihl chainsaws
Andries
This is a 42 footer.
The 4/4 boards have a bit of droop to them.  ;D
LT40G25
Ford 545D loader
Stihl chainsaws
Andries
This is about as wide as I can mill on my old LT30.
LT40G25
Ford 545D loader
Stihl chainsaws
Andries
Best lesson learned: get a bit of chain, order up a Logrite "MegaHook" hook, and turn your logs like this:
It's a niche market for sure, but I do 75 to 100 logs like this per winter.
LT40G25
Ford 545D loader
Stihl chainsaws
sandsawmill14
andries thats some pretty impressive logs :o
i just saw tie logs mainly so i never saw over 16'
for the record those loaders are not mine but its in the deal that one of them is there for me to use t all times ;D
that hook is a good idea but both mills do a pretty good job turning them but if they were long as the ones you are sawing i am sure i would have to get a hook or something to turn them :)
Andries
From the top of the loader it looks like this,
Takes a bit of trial and error, but ya just gotta learn to 'finesse' the loader and load logs onto the mill GENTLY.
This is what a manual toe board looks like after you've been going too fast,
:(  :o  :(
LT40G25
Ford 545D loader
Stihl chainsaws
sandsawmill14
yep one of the loader guys dropped a 16' long 34" dia pine log on my b20 and almost turned it over and bent one of the backstops >:( now i do my own loader driving if having to lay it on the mill instead of using the log deck :)
Andries
Quote from: sandsawmill14 on November 01, 2016, 11:58:02 PM
When I was starting out in this my monkey business, Jake Dean - Custom Sawyer was inspirational when he showed me his setup. He's a don't pith around kind of guy: "here's my advice: go big or go home!"  :D
I've been wanting to set up hydraulics like his operation has, but haven't been able to develop the market to justify the equipment.
Sandsaw: two hooks/chains to the forks on the loader, and there isn't a crooked, lumpy old pecker log that won't roll over for me!  8)
LT40G25
Ford 545D loader
Stihl chainsaws
Andries
So, here's question, how would you guys split a big log with an off centre pith/heart?
eh ?
LT40G25
Ford 545D loader
Stihl chainsaws
VictorH
I had to split a 41" by 12' red oak a couple weeks ago.  I've got a 460 with a 25" bar.  This was my first log that I've ever split but a friend of mine told me to be sure to order a ripping chain.  I did and I was surprised just how reasonably easy it went through it.  I snapped a chalk line to follow and I cut from the top down, flipped and repeated.  I have a couple pieces of square tube to slide over my back stops (21" tall)  that help with turning those halves and not get hung up.  I can not imagine doing this without ripping chain and something to move it with.  I have a forklift.
EZ
I bought a farm jack a few years back when my mill was manual. I bolted a cant hook on it and it works wonders. I still use it on some of those big logs that need split to roll them on the ground or if the hyd turner is having a hard time.
WV Sawmiller
   You guys hit real good points. I did not have any of the heavy equipment like your show - I had part time tractor with forks. Also I am just thinking of over diameter logs not over length logs at this point. The extra long logs have been discussed with all their problems in other threads too and I'm not ready to go there with big and long logs with my equipment yet.
   I used regular chain and was wondering if the ripping chain would have made that much difference. If I understand regular cross cut chain is ground at about a 25 degree tooth angle while ripping chain is ground at about 10 degree. Is this correct?
   I used a 24" bar with a brand new chain not a 28" bar and honestly think I might switch to the 20" bar if I ever do such again to give more power to the saw. I did not chalk a line but started with a pretty straight cut. We did not have heavy equipment to aid in the splitting process. I'd love to see a picture of the farm jack with the hook attachment for rolling big logs by hand. We tried wedges and opened the top about 4-5 inches but it would not completely separate. We rolled the log as far as we could by hand. The problem was we could only roll the log by hand about 60 degrees and my second cut missed the mark in the center taking more time and wasting wood. If we'd rolled 90 degrees to start we should have been able to finish the cut more accurately. (I have watched locals in Africa and in the Amazon making boards ripping logs by hand with no rip fence/guide with a big chainsaw and I have a much better appreciation for their skill now!).
    Another factor when loading and turning these big logs is center of balance. I did not have any side dog extensions so my dogs were only about 12" or 1/3 of the height of the log. If not careful it would have been easy to flip the half log all the way over the edge and off the mill, especially since I had the sawed/flat side on the opposite/clamp side instead of against the side dogs (I.e. The round ride was against the side not center of the mill.) I may have to make me a set of MM extensions to slip over the side dogs in future using pieces of heavy PVC pipe. I suspect the extensions would prevent the log from sitting squarely against the side but since it was rough chainsaw cut nothing was perfectly square like a partially milled log anyway. I.e. Every board was a flitch requiring edging on both sides anyway.
    For a little bit you could also flip and lay the mill on its side as there are no outriggers and it was pretty heavy loaded on one side. That is one reason we used a come-along attached to the truck to turn the log instead of just parbuckling the half with the truck - we had better control with the come-along and could inch the log upright then clamp it in place.
sandsawmill14
i use regular stihl chain on both the 24" and the 28" bars  :) if a log is 40" or less and doesnt have many knots i can saw down 1 side with the saw at 90* so i am getting full cut of the bar then cut all the way through the log on each end and it will split pretty easy with wedges i cut out of 4x6 about 12" long  :) if you cut all the way through on both ends and down the top there's not alot of wood left on a 40" log :)  gum can be an exception i guess its the spiral grain :) i always have a loader at this mill but when i am at one of the other 2 i dont have so i have to use the wedges
andries i split them the same as one with the heart centered right down the middle with no regard for the heart :)
fishfighter
I learn to just not saw them big suckers. Way to much work. Then again, I saw just for myself. :D
Kbeitz
This is what I use to roll my big logs. Works like a charm.
It swings out of the way when I'm done.
Love machine shop work
and Wood work shop work
And now a saw mill work
Dakota
This thread is a pretty good advertisement for a swing mill.
Dave Rinker
WV Sawmiller
Quote from: sandsawmill14 on November 02, 2016, 07:21:39 AM
SS14,
   This log was about 16'6" long, I sawed 90 degrees the full length with the 24" bar, I had sawed completely through on each end for the full 24" bar length and we fabbed and used some wooden wedges about 4" thick and they still would not completely separate the log. That remaining 12'6" with 12-14 inches of holding wood would not let it turn loose without cutting from the opposite side.
scully
I have had my share of huge diameter stuff on my 40 . My first mobile job was a freakishly huge dia. cherry , I split it and they used 2 small tractors to position it . I should have charged that guy double , not only for the job but because he was rude as heck .  Another one that comes to mind is a very large red oak  That one cost me a Hydrolic motor . And again I charged half of what I should have .  I guess the best ones were a couple large walnut jobs they went well .  Any more I ask what type of equipment they have ,and make it clear that there is an upcharge for oversize !
I bleed orange  .
EZ
Pictures, I have a heck of a time putting pictures on here so maybe I can get my wife to put one on with the farm jack.
I split logs the way most of these guys do except I use 2x4 oak wedges cut 14 to 16 inches long. The 2x4 wedges seem to drive in alot easyer.
