New and waiting
Started by Jake-n-Texas, March 11, 2015, 09:41:09 PM
Jake-n-Texas
Hey I'm new here and just purchased a woodlands mill today so I'm waiting on it to come in. I'm 31 and live in houston but the mill will be in limestone county at my parents weekend place where I plan on building myself a cabin close by with the wood I cut from the mill. I plan on just cutting wood for myself and friends and family. If I could make enough to pay for the mill I would be super happy. I'm very new to working with wood but my stepfather has a woodworking shop where my mill will be. I was going to get the HF mill but decided to get the woodlands. I've already went and picked myself up a cant hook, chainsaw, skidding tongs for when it comes in. I was wondering if their is anything else y'all can think of that I might need.
tmarch
Welcome and congratulations.  Sorry not much I can think of that you will need except some additional bands and safety equipment.  Have fun and enjoy!!!!!!!!!! 8) 8)
Retired to the ranch, saw, and sell solar pumps.
customsawyer
Congrats on the mill and welcome to the forum.
www.thecustomsawyer.com
pineywoods
Bbblades...they will dull quicker than you think. Don't wait untill all your blades are dull before you think about sharpening...For a beginner, usually the best option is buy your blades from someone who does re-sharp...
Gasawyer
Welcome to the forum and good luck!
Woodmizer LT-40hdd super hyd.,Lucas 618,Lucas 823dsm,Alaskian chainsaw mill 6',many chainsaws large and small,NH L555 skidsteer, Int. TD-9,JD500 backhoe, and International grapple truck.
Welcome to the Forestry Forum, Jake-n-Texas, and I wish you the very best with your new venture.  Ask questions and take some pictures.  (Picture posting instruction are at the bottom of the index page.)
Jake-n-Texas
Thanks everyone. I do plan on ordering a ten pack of blades before the mill comes in, just not sure what ones I want to get yet. I do plan on taking pics of everything as I get going.
dean herring
Welcome to the forum . Caution it can be habit forming.
Failure is not an option  3D Lumber
RM Farm
Welcome to the forum, and congratulations on your mill. I can say you are really going to like that mill. Did you order an extra track? Or just get it stock? Either way, loads of fun!!  :)
Thanks, Robert
Woodland Mills HM126; Kubota L3200 with FEL, quick attach forks.
Jake-n-Texas,welcome to the forum.Should not take long to get your money back from the mill cutting out a cabin. How are you getting the logs to the sawmill? You may have to take an axe or something and scrape the bark off where the blade will be cutting. Blades do not like dirt. Lay down 2 logs the opposite way the mill sits,just a little higher than the mill too,so they will roll on easier and put your logs on them and roll them onto the mll.If you are cutting the trees you need a hard hat and chaps too. Good boots too. And a good back!!  ;D
Chuck White
Welcome to the forum, Jake-n-Texas, and congratulations on the mill.
slider
Don't forget to cut a good supply of stickers so your boards will dry properly.
al glenn
I would go with two boxes of blades, 10 blades to a box.  That way, you can send off one box to get re-sharpened while you are using the blades from the other box.
fishfighter
Jake, I have the same mill. Got it about 1 1/2 months ago.
When you get it, try to get a level area to put it together. First things to cut are some 6x6 cants. Something that you can build a platform to move the mill on to get it up higher. That will make life easy once you really start milling.
I built that to house the mill head. BIG NOTE! Get some 3" screws to screw everything together to hold them in place or you can knock things over. Yes, I did. ;D
What kind of trees are you planning on milling? I'm milling hardwood with the 10 degree blades and I find it hard on the mill. I will be ordering some 7 degree blades to see if that helps.
Another thing. You will have to adjust everything a few times to get things set. You will need a 14, 16mm socket to put everything together. Any questions, just call them. They are very helpful. Only question they couldn't give a answer to was how much oil to put in the motor. Even the motor instructions didn't say. That is a little over a qt. :D
Jake-n-Texas
Yes I did order an extra six feet of track with it. I also have access to two tractors that I will be using to skid and load the logs with.
fishfighter
With the extra track, I'm able to cut 16'6" boards. A good set of saw horses to put on the other side of the mill to stack your boards coming off the mill helps. Also stacking the cut offs there, you can cut those up with a chainsaw. In my case, I taking thick first cuts. I will be selling that as firewood next fall. I'm cutting Red Oak which brings a good price for firewood in my area. No waste there. ;D
Jake-n-Texas
I really like your setup fishfighter. I will be sawing different oaks, Ashe juniper what people call cedar around here, mesquite, pine and hopefully I will get a hold of some pecan and walnut.
What brand blades do you guys think I should try first.
schmism
FYI as to how many blades.   Consider this.  many of the guys that make a living at portable milling will change blades at lunch and at the end of the day.   so roughly 2 a day without any crashes (nails, back stays etc)    If your a hobby miller you may be able to extend that to a blade a day.   so a box of 10 blades may last a 5 to 10 days of sawing.   avg turnaround for Wood-Mizer Resharp is about 5-7 days.
Thus the recommendation of 2 boxes when getting started.
039 Stihl 010AV  NH TC33D FEL, with toys
fishfighter
I bought a box from Woodland when I ordered my mill. I'm about to order another box or order two or three 7 degree blades to try. Like I said, my mill is having a bit of a hard time cutting wet, fresh fell Red Oak that are a avg of 25" wide on the butt end.
My usage has been about one blade a day to about 500 bf.
goose63
Welcome to the Forum watch the back stops  and have fun I sure am
goose
thank you to all the vets
sandsawmill14
Quote from: dean herring on March 11, 2015, 11:17:48 PM
x 2 ;D
Jake-n-Texas
So I went a head and order ten blades from timber wolf.  I can't wait for the mill and everything else to get here.
valley ranch
Happy for you Jake, that all sounds great. We all like pictures, so when you've time show us the new mill,,,,,,,,,,,and what you build with it.
SawyerBrown
Welcome, Jake!
What else you gonna need?  A strong back!  Oh, wait, you're 31 ... never mind.
Have some fun!
Texas Ranger
Welcome aboard, Jake, just a few more Texans and we can invade the north!  smiley_big-grin2
