Wood ashes for traction
Started by Bert, September 24, 2018, 01:17:54 PM
Bert
My father always put wood ashes from his woodstove on the driveway for snow and ice traction. It  works surprisingly well. I recently purchased a side by side and was thinking of a spreader for ashes from my outdoor boiler to mount on the back to help out this winter. My driveway is 1/4 mile or so long and hand spreading is a pain. Would a salt spreader work? I have zero experience with them.  The driveway is gravel and this would be done once plowed just to give some bite in snow and ice. Ashes to be spread would be dry, yet given time to be completely cool before spreading. I dont want to burn up my plow vehicle :D
Saw you tomorrow!
Ljohnsaw
I suppose in the spring the ash would just sink into the gravel and you would be through with it.  I've accumulated a bit of sawdust ::) and was thinking that would be good to spread on snow/ice for walkways.  Out in the country, you could just blow it off in the spring.  The really nice thing is it is really light, unlike spreading sand.  Anyone use sawdust for traction?
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
gspren
My experience was that the ashes from coal (cinders) provided great traction while the wood ashes mainly helped melt the ice/snow because of the color. Maybe if your getting more chunky ashes than me it's different.
mike_belben
I put sawdust, bark and woodchips on freshly dozed up clay.  Keeps it from sticking to your boots in the rain, and from drying to powder during drought.  Traction wise its so so.  Better than nothing but not gonna replace crusher run anytime soon.
Praise The Lord
Ivan49
If you put sawdust on ice the ice will not melt but you will have good traction. Had a guy tell me once he put wood ashes on his drive and it worked real good until he got flat tires from the nails that were in the pallets he burned
curved-wood
I use both saw dust and ashes. I play with both depending on the temperature and the surface of the drive way. I keep both inside in a heated space. Ashes is dirty around the house. Green sawdust kept at room temperature will stick nicely to a icy surface in few minutes and will stay on the surface. I guess it is the water in  the green sawdust that make it stick to the ice. It does not fly in the wind like dry saw dust or ashes. I keep the sawdust in 5 gallons pails :easy to handle. Sometimes sawdust is better than crush stone which has a tendency to sink specially if it is stored at room temperature
bodagocreek2
Ashes work ok, just a little dirty. I find crusher dust works the best, especially on ice.
hedgerow
Quote from: bodagocreek2 on September 25, 2018, 06:05:14 AM
On our white rock drive ways (Limestone) ashes and saw dust didn't ever seem to work good for winter traction and left a mess to be tracked in the house and shop. I have had better luck with the crusher dust or our rock quarry used to call it waste and gave it away and you just had the cost of hauling in it. I used to have a pile around all the time for filling pot holes in the drive and put some on the drive for winter traction. Then folks started using it for fill sand under concrete and putting it in cold storage farm equipment buildings to keep the dirt dust down and then the quarry started selling it for almost the same price as one inch crusher run. Now days I have a pile of one inch crusher run for pot holes and for winter traction .
GRANITEstateMP
I use the ash on the end and middle part of the driveway.  It's free, and it works ok.  No nails in mine ;D.  I keep don't use it near the house, I don't want to track it back in!
We are part way down a pretty good hill, so we get a good bit of melt off at the end of the driveway.  I'll put down some ash after plowing, and it'll help.  Our town has a bin with sand at the highway shed that's for townspeople use.  Sometimes I'll put the ash down, drive down to the shed, fill the ash bucket with sand and really put it to that end of the driveway!
Hakki Pilke 1x37
Kubota M6040
Load Trail 12ft Dump Trailer
2015 GMC 3500HD SRW
2016 Polaris 450HO
2016 Polaris 570
SureTrac 12ft Dump Trailer
Logging logginglogging
I also have a 1/4 mile drive way, and use ashes on the steep part, the only thing about spreading them with the new side by side and a spreader is that wood ash is very corrosive..
Weekend_Sawyer
In icy conditions I always put fireplace ash on the pad in front of my carport and on the ramp leading off of my porch to the pad. Works well, take your shoes off before you come into the house. ;D
Imagine, Me a Tree Farmer.
I have a 500 foot driveway that does not get the sun. I put mine in the bucket of my tractor and spread with a shovel.  I don't get many ashes.
47sawdust
My wife carries a bucket of ashes in her Volvo year round.She was some proud of herself after getting a loaded log truck going  after a stop on an ice covered bridge.
You go girl!
Mick
chubby
While I too find ashes great to use on my driveway when needed, I don't think you're going to be very impressed using a sand spreader for it. The ashes absorb humidity quite quickly and they're pretty light and powdery. Sand and salt spreaders are meant for coarser material with pretty good weight.
You'll at the very least need to empty it and clean it when you're done as once any humidity in the ashes freezes, you'll have a nice solid ash block in your spreader.
Al_Smith
The big old farm house I grew up in at one time had a stoker fed coal furnace and used about 12 tons of coal a year .We would spread the "clinkers" in the driveway .They were just about as hard as gravel .As a boy I must have shoveled 100 tons of coal in that thing .
As far as wood ash ,my insert burns it all into powder .There isn't very much unburned .I suppose on glare ice it could provide some traction but I've never tried it .
Bert
Thanks for the advice. Im going to scrap that idea and just use a bucket as I have in the past. I hadnt considered them being corrosive or the humidity clumping factor.  Both are good points. They eat out a metal wheelbarrow in two years. Salt spreader idea is out!
Saw you tomorrow!
John Mc
Quote from: Al_Smith on September 26, 2018, 05:42:36 AMAs far as wood ash ,my insert burns it all into powder .There isn't very much unburned .I suppose on glare ice it could provide some traction but I've never tried it.
That powder works surprisingly well for traction.
