tree farmer good and bad
Started by logman81, August 17, 2012, 04:35:48 PM
logman81
Looking into possibly looking at a c6 tree farmer it's a older model. Looking to get info on them as far as the good and bad things about them.
Precision Firewood & Logging
Mark K
What engine-tranny setup does it have?
Husky 372's-385's,576, 2100
Treefarmer C7D
Franklin 405
Belsaw m-14 sawmill
lumberjack48
C5-D , C6,  basically the same issues as your ole Bone.
Find out what motor, and tran, tire size
logman81
Not sure what trans it has but it has a detroit and 18.4x34 with chains on all four.
lumberjack48
example, i just looked at a C5D on C'S L, rebuilt big Ford Diesel, rebuilt winch, rebuilt transfer case, tires good, good looking skidder, asking 7,000., they got it listed as a C4D, i don't like that dent in the pipe.
That C6 is most likely was a 453, but might be a 353
donny hochstetler
find you a good running clark, they are tough, easy to operate, very stable, parts are reasonable, you will not have winch trouble, the only thing with the older clarks, are the old dry brakes, might convert the parking brake over to a disk, n your good to go, I had a 666 b with a cummins, now I  have a 65 f, I love em, wish they would still make em,  I always get a kick out of people, they ask you, what kind of skidder you got,     clark  they look at you kind of funny, then they start talking about there timberjack, which has a clark winch, clark rearends, n some of em clark transmissions, :D this is just my opinion, i"v runem al,l there really all good machines, main thing is the guy running them, but where I live we need good brakes, n the older stickshift machines with dry brakes, just do not work, a good way to get killed, hope you find a good one, just take your time, there outthere n dont be afraid to travel for the right machine, when you find it you will be partners
bushmechanic
I'm with lumberjack48,18.4/34 is not what should be on it for tires,usually larger ones like 23.1/26 or 24.5/32 .They normally had a 453 Detroit or a 6 cylinder Deutz .Overall there great machines only for having a Gearmatic winch.
logman81
All good opinions and info guys! The one I'm interested in is listed on vermonts CL it's the c6 listed on july 13 Hartford NY. Havent called on it yet to get the full scoop on it. Waiting to see what happens with mine first.
oldseabee
Regarding the comments about the old clark skidders. I worked for Clark as service rep in Southeast. You are right about the brakes. If you have hilly terain, look for old 667,they had wet disc brake and parking brake on the back of the 28000 transmission, flat land or swamps, might not be an issue. The other advantage of the trans brake is that it is protected from debris. Trash in a dry driveline brake can start a fire, need to keep it cleaned out.
lumberjack48
I don't like the color, looks more like a C5-D, has the same planetary's as a C5-D. I can't see the exhaust pipe real good, but looks to big for a Deutz, or Perkins. i believe is a 45-3 Detroit.
Skidder looks good, paint can cover up a lot of problems, I'd have to abuse it for about an hour, driving full throttle though all the gears, dosing, winching, some dealers didn't like my road test, when others would say go for it, its a good machine. My father got embarrenest when i was trying out a C5-D with the big Ford diesel for him. I pushed snow for about 1/2 an-hour full throttle, winched some old equipment around, this was at Treefarmer Sales here in Bemidji. I got off poped the hood to check for any blow-by in the motor, leaks and ect. I turned to dad, an said its a good one buy it, i think he ran that skidder 15 yrs, never had a major issue with it.
I know what most on here think about Gearmatic winches, i used-em 28 yrs, besides putting bands in a couple of-em, rebuilding the master control, putting a live swivel on one. Its the only winch i'd want, just being i know how simple they operate. The model 20 Can-Car would start to act up, i'd pull the cover, blow it out, check clearance on shoes, make sure brake band was releasing properly. Put the cover back on, it worked perfectly, i didn't do nothing to it, about every 3 months it did this.
My father and me rented a C6 one winter, we were falling behind with the one skidder. The snow was 4' deep in the swamp and the winter was getting short. It had a 6 cylinder Perkins with a Alison power shift. It was different to run the fuel petal was on the left had side, with a power shift this works out very good, you can hold the brake and step on the throttle at the same time. My S8 IH  had the throttle petal on the right hand side with the brake on the left hand side.
The C6 was a good machine, the only thing we weren't used dumping 30 plus gals of fuel a day in a skidder, she was a thirsty one.
If i was going logging i'd offer 5 k for the one in the picture, that would be a good buy.
Mark K
Thats a old one. Has the round pipe risers on it. Im with lumberjack it must be a Detroit. I have a Duetz 6cyl in my C7D and the nose is longer and the exhaust is midway up the hood. Mine has a clark powershift with a torque converter. Has 23.1-26 tires. It'll pull one heck of a hitch. Easy on fuel too. I burn less than 15 gallons in a ten hour day.
Treefarmer C7D
Franklin 405
Belsaw m-14 sawmill
treefarmer87
my c6 is a great machine. it is a perfect machine to me. they usually have a 453 or 453T or a 6 cyl deutz, with a 4 speed NP 542 trans. with either a gearmatic 19 or can car 20 winch, i prefer the can car.
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
1999 John Deere 748G
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
lumberjack48
tf87 you still have a bad taste in your mouth because of all the trouble with the C5-B you had. Like i've said before it was a C4 with a 353 Detroit, way to light if used hard in big wood. A C5-B isn't half the machine a C5-D is, i've ran-em side by side. The reason i stayed with a C5-D is about 75% of my jobs were selective cut, a C6 is more of a clear cut skidder.
Don't get me wrong the C5-B is a good skidder, there was a reason it was called a pulpwood special.
treefarmer87
it was a good skidder, i miss it sometimes. honestly my favorite is a c5D. its just the right size. but i will never get rid of my c6. i love the power and how much wood i can move with it. it handles those grade logs effortlessly. :)
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
logman81
Glad you like your c6 it's a nice looking machine. As far as the color on the one in NY it's not the color of the machine that gets the wood out and it may be old but it's a working machine.
Mark K
Theres nothing wrong with old machines as long as they've been taken care of. My Timberjack that burned was a '66. Id still be running it if it didnt burn. Look it over real good before you commit to it.
Treefarmer C7D
Franklin 405
Belsaw m-14 sawmill
logman81
What ever I do go to look at I will test it very throughly!
lumberjack48
I bought a bran new working machine [ $80,000.00 ] i ran it about a month and the motor dropped a valve.
logman81
Some times even a new machine can have problems.
treefarmer87
i know a big time logger here who just bought a 2012 648H this year, and about 4 months ago had to get a $24,000 reman trans from john deere smiley_thumbsdown :-[ :'(
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
logman81
lumberjack48
I don't know how they do it, i always said there must be some sliding under the table with the big mills.
DDDfarmer
so what is the difference between the C5D and my C5C ?   sounds like the same machine  353-4 speed-gearmatic 20 and built like a tank...
Treefarmer C5C with cancar 20 (gearmatic 119) winch, Husky 562xp 576xp chainsaws
logman81
I think your right lumberjack48 about the skidder I'm interested in is s c5 he has it listed now as a c5?5
lumberjack48
Does it have a 3-53 or 4-53 ?, if its a 3-53 its a true C5-D, if its a 4-53, i think its a early C6, on less the 4-53 was put in it by somebody.
