No Mold on my Pine Boards
Started by POSTON WIDEHEAD, September 11, 2013, 08:09:09 PM
POSTON WIDEHEAD
It is STILL hot and humid in S.C. I and a lot of us have talked about mold.
Even this week, if I stack and sticker my Pine under my shed next to the mill it will mold in 2 days.
This particular order was stacked outside in the WIDE open. This whack was stacked and stickered for 5 days until the customer from N.C. could pick it up. I was surprised....not one bit of mold.
Notice the bottom half was stack with a wide space between each board and the top half was stacked against each other. I feel like this let more air get up under the stack.
By the way, we have not had any rain in a while so I didn't have to cover it up. The boards look very good.
I may start using some of your guys way of stacking outside since it seemed to work this time.
drobertson
Looks good!  and plenty of air for sure, what a way to load a truck, done that a few times, not my favorite,  just check my flat stack now going on 6 days, just a little white showing, should be picked up tomorrow, just siding on a calving feed shed,     david
With a stack that wide, leaving a gap between the bottom part of the stack had to help a lot.  At least now, in a few weeks, we will get outstanding drying weather.
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
ladylake
 Yes only stack 4' wide or as long as your forks are with 3 or 4' between stacks.   Steve
nk14zp
Did the metal dust from the nails on the other job help prevent the mold?
Belsaw 36/18 duplex mill.
Belsaw 802 edger.
http://belsawsawmills.freeforums.org/
The sun and wind is your friend.The quicker the outside of the boards dries the less chance for bluestain.My own belief is some logs from some areas are more prone to stain.I have had limited success with fans blowing on fresh stacked pine under cover.Only sure cure is cool weather. Frank C.
NMFP
Make your packs narrower, a good foundation 20" off the ground provides better air flow and keeps moisture from entering from the ground level.  The reason you have mold is your trying to naturally drive air through a small chanel without any force (fan).
Make narrow packs, 20" off the ground foundation and direct your pack of lumber so that the wind blows through the pack.
Seems as though I have to answer questions like this every week anymore and surprisingly, kiln drying and air flow is what I am covering in class this week!
Quote from: POSTONLT40HD on September 11, 2013, 08:09:09 PMThis particular order was stacked outside in the WIDE open. This whack was stacked and stickered for 5 days until the customer from N.C. could pick it up.
The OP's choice for temporarily sticker stacking lumber scheduled for pickup was cleverly thought out and served his purpose very well in this instance.
The walnut job is on the right side.  ;D
Yes, David did a good job of preparing the customer's lumber.
5quarter
I agree with what someone here said once: "If I have to sticker it, it's now air dried and I bill for it". That, BTW, is some great looking lumber.
Blue Harbor Refinishing
Dave Shepard
5quarter, I agree. The work is done, just have to wait a couple of months for the drying. I suppose if you had a refrigerated trailer you could dead stack it this time of year. :D
