wood mizer solenoid
Started by bigal, December 05, 2015, 12:22:12 PM
bigal
hey everyone , so got my wood mizer back for the shop all fixed up last week and got a got day to work with it all was going good until the hydraulic solenoid stop working ,so i check it and it was not letting the 12votls trough so i had a new one shipped and worked for about an 1 hour and now its doing the same thing does anyone have a idea of what could be the cause thanks
It's almost impossible to trouble shoot without being there.  The power strip needs to be clean and the "contact button" has to have good spring contact.  It's possible that the microswitch could be erratic at times.  Mine was before I replaced it.  Also, I got a bad replacement solenoid that was replaced by WM under warranty.  Of course all is assuming that your hydraulic motor is OK.
Chuck White
Welcome to the Forestry Forum, bigal.
Ga Mtn Man
Does the solenoid click when you move a hydraulic lever?
Kbeitz
Most solenoids are made the same inside.
Maybe this drawing will help you trouble shoot..
Love machine shop work
and Wood work shop work
And now a saw mill work
bigal
Yes the soneloid does click when I try to activate it
Kbeitz
If you put a 12 volt light in series with the wire it should NOT light when trying to start.
If it does the current is not going through your wires. Good way to test for shorts.
Solenoids can click and not make contact.  I replaced the continuous duty start/generator solenoid on our golf car yesterday.  It was only about a month old and probably had not operated over a dozen times.   :-\
POSTON WIDEHEAD
I just replaced my Solenoid along with my micro switch.
Mine was dead....no clicking or nothing.
I replaced it and now all is fine.
You may have a dirty ground.
I tested my grounds by taking a screw driver and crossing the 2 big bolts on the Solenoid and then turning the key on. My HD motor was running strong. So I know I was getting plenty of volts to it.
Kbeitz
Dirt or millings from when it was made can jam up the electric magnet inside the Solenoid.
The copper bar can also burn off...
drobertson
check the grounds,  no other issue other than this, unless it's bad new ones, not that likely,
