Band mill Router Plane
Started by Kbeitz, January 25, 2018, 01:09:09 PM
Crusarius
I am really surprised after you put the bit in you didn't run it right then and there. I would not have been able to avoid doing that :)
Kbeitz
I want to make sure I smile the first time I run it... I put to much work into it to have it not work right the first time.
Love machine shop work
and Wood work shop work
And now a saw mill work
catalina
KBeitz, good thing you don't live closer to me-Id have to stop in and introduce my self and then Id never get anything of mine done. I love gadgets, dohickies, whatchmacallits  and anything else custom made for a purpose-sometimes even if it doesn't have a purpose, lol.
Kbeitz
You'r not that far away. Stop in...
Kbeitz
First cuts today.... I'm smiling... Video coming soon.
Ljohnsaw
 8)
From the looks of the shadows, that wasn't a real flat slab to start with?  Was hard to tell before.
Crusarius
that looks great. how bout some close ups of the finish?
Kbeitz
Kbeitz
Quote from: ljohnsaw on March 15, 2018, 02:05:03 PM
8)
I was cutting at least 1/2" off at the high spots.  I took it all all with one pass. 1/2"to3/4" wide by 1/2" deep cut all at once. Take about 10 minutes to do one side of the slab posted in the picture.
Crusarius
thats nice. now you going to get a sanding pad for it? :)
Kbeitz
Quote from: Crusarius on March 15, 2018, 03:43:53 PM
I make one...
Kbeitz
Kbeitz
Under cut worked so much better than over cut... Tried both.
Crusarius
Is that the same as up cut and down cut?
Kbeitz
My best cut is when the bit digs in from the bottom of the cut. Not the top... I use the one on the left.
Crusarius
ok that makes sense now. climb cutting is really hard on tooling to cause the router is being pulled through and depending on how much slop there is in the feed it could jamb the router taking to big of a bite. I have the same problem when milling steel. But with steel I do get a nicer finish climb cutting.
Kbeitz
Yep climb cutting can snap a bit real fast on my Bridgeport.
justallan1
Nice job and a great project.
starmac
Kbeitze, how wide is your bit? The reason I ask is it looks like the bit on the woodwizz is 5 inches and even an optional 6 in bit. It looks like your outfit is built heavier than the factory one, do you think yours would handle a bit that wide?
starmac
I have no experience in anything like this, so don't laugh at my question.
I see you are having to take off up to a 1/2 inch in the high spots, would it pay to cut your slabs a little bigger and resaw them after drying before planing?
Kbeitz
Quote from: starmac on March 15, 2018, 07:05:43 PM
I think it would help it I would stop using junkyard blades but that's not going to happen. The price is right.
Kbeitz
Quote from: starmac on March 15, 2018, 07:01:24 PM
My bit is 2-1/4" wide. If I buy the right cutter head I'm sure I could go bigger. The one I bought only cost $30.00. The 5" with the insert bits cost $502.05.
starmac
Unless you wind up with the need for speed, then I think your plan is outstanding with that kind of price.
Ljohnsaw
Quote from: Kbeitz on March 15, 2018, 08:42:31 PMThe 5" with the insert bits cost $502.05.
We all know you are just waiting to find one in the junk yard for a couple bucks...
starmac
I am not sure about the junkyard bands. I know of sawyers that sets nd resharpens their brand new blades, claiming it is better, especially setting them. I don't know if sometimes a tooth gets off some in the packaging or if it is just an assembly line thing.
I have read several times that guys thought their blades cut better after they have sharpened them than they did when new.
I would think your junkyard blades would probably be as good as new once sharpened. I bet someone is trashing them after one use, instead of having them sharpened.
