Rotted Cedar
Started by REGULAR GUY, October 16, 2013, 01:17:37 PM
REGULAR GUY
I cut some Cedar here in So. East Mo. and some of the center has some rot. I was planning on using it for window and door trim (2x4's). I am told that it's still good lumber cuz once it's cut it won't spread. I am at a stand still,  use or not? What do ya'll think?     RegulaR GUY
mesquite buckeye
As long as it stays dry the rot won't advance. In a wet, or frequently gets wet location, don't bet on it. Heart rotters are very patient beasts, and take advantage of any opportunity. :snowball:
In a living tree there is a much higher moisture level, and this allows even durable wood like cedar to gradually rot out. But once you get the still solid wood sawn and dry, it will be normal durable cedar.  So saw it, and just discard the punky looking parts. The rest will be fine.
My cedar on my land in Maine is that way. But mine might be a foot across and I can shove my arm up into the hole in the butt log. takes at least 8 feet to use the whole log. hard to get many 2x4's from a tree. I built a porch out of it. I had a hard time to get 4x4 8 feet long.
