Dusted off the mill yesterday
Started by brdmkr, July 21, 2010, 11:08:32 AM
brdmkr
I finally cleaned the carb on the ole Lucas and sawed up a pretty nice red oak yesterday.  I cut about 200 bdft of 8/4 and a couple of 6x6 beams.  I'm hoping that they will air dry to the point that I can put them in the kiln around Christmas.  I'm planning on making a bed with the fruits of my labors.  It sure felt good to run the mill again.  I had 4 BIG pine logs delivered about 3 weeks ago that I need to cut.  I am sure they are a nice shade of blue by now :)
customsawyer
I thought I could hear it running. Sounded like it skipped a couple of times when you first started. :D
www.thecustomsawyer.com
brdmkr
It did skip!  Howd you know?
About 2 weeks ago (before I cleaned the carb) I am sure that it smoked enough that you could have seen it over your way.
