Pine tree milling
Started by asm9296, May 19, 2019, 03:59:21 PM
asm9296
How long can a pine tree sit after cutting before milling?  Loblolly pine.   Bark left on.
   I am sure it varies but around here we mostly have white pine and in the warmer months after a few months you are getting seriously at risk for pine borer beetles that will cut about 3/8" holes in the wood. As I understand if you can debark them that greatly reduces the risk. I bought spud with about a 4" wide head and a sturdy 5' handle at HF I plan to use for stripping bark off my logs. I have not used it enough to verify how well it will work yet.
Lawg Dawg
Better hurry up and saw it, trust me
2018  LT 40 Wide 999cc, 2019 t595 Bobcat track loader,
John Deere 4000, 2016 F150, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong. Woodmaster Planer, and a Skilsaw, bunch of Phillips head screwdrivers, and a pair of pliers!
100,000 bf club member
Pro Sawyer Network
Note:  Adding your location to your profile greatly helps with answering questions.  :P
In my location, during the Winter, 2-3 months is generally OK.  Summer, within a month is best.  As LD eluded to above, the log starts degrading the instant that it hits the ground.
richhiway
It depends. I have cut pine that was two years old that was good without pine borers. Other times they start chewing up the wood right away,you can hear them.They only start when it is above freezing so you will be safe in cold weather. If you want some pine with "character" you let it sit for a few years,it will get blue stain and the borers will chew all those pretty holes!
Woodmizer LT 40
New Holland 35 hp tractor
Stihl Chainsaws
Ford 340 Backhoe
@asm9296 said "Loblolly" which puts him somewhere in the South.  Not much cold to prevent borers.
Southside
Yup, and with the furnace just turning on they will begin to stain quicker and spoil faster. Ironically white pine lasts longer on the ground than loblolly.
