Lt30 head hanging up
Started by trapper, July 30, 2017, 10:41:28 PM
trapper
Lately the head on my 1987 LT30 has been hanging up on the way down.  Normally at 18 inches and down.  I use ATf on them.  The rails are black and dirty.  What is the best way to clean them?  Other problems to look for?  I use a leaf blower to clean the mill when done sawing.  The mill is almost always under A roof.
Chuck White
I've had that happen a couple of times over the years and I wiped the masts down with a fine sandpaper then wiped them with ATF and that ended the problem for a few years!
Crossroads
Is it coming up solid or is it kinda jerky coming down? If it's jerky, tightening the chain may help.
Crusarius
Simple green is a good environmentally friendly degreaser.
trapper
Chuck Whites sandpaper idea worked.  Thanks for the rest of the hints.  All something to remember.  It was hanging up on the way down.
