142 e Husquvana- trouble starting
Started by markkelly, November 09, 2011, 11:49:09 PM
markkelly
 ??? ??? ??? rebuilt carb, checked fuel filter, compression about 90 psi, new plug, new air filter, checked fuel lines, new fuel good mix, adjusted idle, high and low???  the saw will start runs ok , runs good on high end but when it warms up it is hard to start if it starts at all.  muffle??? any suggestions at all would be welcome.
LT 10 Woodmizer, Stihl, Husquvana,wood carving tools, Ford 3000 Tractor, Trailer.
kenskip1
I hate to bring bad news but if your compression is anything below 125 you have a problem.I would pull the muffler and see if the piston is scoured.Ken
Stihl The One
Stihl Going Strong
Stihl Looking For The Fountain of Middle Age
lumberjack48
Check to see if its getting to much gas or starving for gas.
snowstorm
low compression. that will cause hot start problems. 90 is not enought
