Timberjack 230 winch spring removal
Started by Logger207, May 24, 2018, 02:28:01 PM
Logger207
I am working on replacing the seals in the hydraulic winch brake cylinder (Hercules, timberjack 230) I have removed the snap ring on the bottom of the cylinder but can not separate the shaft from the cylinder. I know there is a big spring inside but what is a good method  of removing the Piston from the cylinder so I can replace the seals? Thank you in advance.
