Dump trailer log arch / winch setup
Started by Jimmysmill13, November 04, 2018, 09:32:16 PM
Jimmysmill13
I just finished up modifying my dump trailer with a 13000lbs winch and log arch. Just sharing some photos and video for everyone.
milkie62
I love it . A great use for a dump trailer. I had a small mowing business and have a 7x12 dump trailer that would be a great project to do. My trailer has a full width landscape gate so to keep from hitting dirt the log could be winched up blocked and rolled right into the trailer with no lifting.
kelLOGg
Nice job and welding, too. What are the dimensions of the steel in the arch? How easily does it disassemble?
Bob
Lawg Dawg
That's top notch!  Thanks for sharing!
2018  LT 40 Wide 999cc, 2019 t595 Bobcat track loader,
John Deere 4000, 2016 F150, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong. Woodmaster Planer, and a Skilsaw, bunch of Phillips head screwdrivers, and a pair of pliers!
100,000 bf club member
Pro Sawyer Network
Jimmysmill13
Quote from: kelLOGg on November 05, 2018, 05:30:40 AM
Bob
I used 1.5" x 3" tubing and has a .25" wall thickness. Removes by pulling 4 pins. Its removed fairly easy but it dose have alittle weight to it. I can lift it into place myself. Better with 2 people tho.
Great idea and the craftsmanship is superb.  8)
sealark37
Does your dump pump have the guts to dump a trailer full of logs?
Jimmysmill13
Quote from: sealark37 on November 05, 2018, 01:47:08 PM
Yes it will lift a load of logs with ease.  The trailer uses a scissors lift and is rated for 20000lbs.
Crossroads
Travis James
I have plans to do the same thing to my dump trailer. Have you made any modifications? Is there anything you would do differently?
Rookie Sawyer
Walnut Beast
Looks good. It looks a little light duty how you have your roller mounted. Might want to beef up
mike_belben
Those rollers will wreck a cable by sucking it into the corner and jamming really bad.  Keep snapring pliers and a punch in the truck, You have to take the long roller pin out to free it.  Pain in the ash.
Nice fab work.
Praise The Lord
Brad_bb
I like the concept of the dump trailer.  The photo makes the arch look a bit short compared to Matt Cremona's for example.  Taller I think gives more leverage.  Can you show the mounting of the Arch to the trailer?  How heavy a log can you put in the trailer?
It's funny, I would like a log arch trailer, but don't have time (or a heavy enough welder) to make one.  I'm surprised that no one makes one for sale.  At least has a good design for a trailer like this offered at an optional upgrade.  I suppose most would rather just sell trailers and not all the additional issues of customization.
Walnut Beast
Looks like he is using the stake pockets with pins to hold in of the framework he made
mike_belben
I think its a big jump up in liability category to get product liability coverage on a overhead lifting apparatus vs just a trailer.  Exponentially higher odds someone gets hurt by cable loading logs vs the relatively safe operation of regular utility trailer duties.
Praise The Lord
mike_belben
And btw guys thats a fixed arch, not a pivoting one.  Well, other than the arc it travels by raising the bed.
Praise The Lord
DDW_OR
