Building a Table - Ideas Needed
Started by Ianab, August 01, 2005, 07:03:58 AM
All this talk of nice slabs of wood reminded me of an uncompleted project  ::)
A new kitchen table.
This is what I have so far...
I will probably trim the slab up into 2 rectangular table tops as the sapwood has started to rot. (the tree lay on the ground a couple of years before it was sawn  :( ) Slab is about 3 " thick, so table design needs to be .. ummm.. solid. Kitchen is being redecorated now with cottage type cupboards and some partial shiplap timber panelling, so a rustic style trestle table will fit in.
I just need some more inspiration  :D
Cheers
Fla._Deadheader
Just a question. Isn't 3" a little thick for a table ???  Down here, we sell 3" and up for Mantles ???
  I have always liked Trestle Tables. I have seen darker "Breadboard" ends, to accent the color of the tables. Also, the natural edge is really catching on here.  Ed showed a customer how to create a natural edge, where we had to trim the original away to saw the wide log. Customer was tickled.
  Nice slab, Ian. Macrocarpa ??
pigman
Like Rodney, I like trestle for thick table tops.  The removable trestle makes it easier to move the table. This maple table I built for my daughter is not a slab but I think a base like it would look good under a slab. You could use a contrasting wood for the base or the same wood. The fasteners under the top must allow for movement of the slab.
Yup Harold, Macrocarpa Cypress, just a little one  ;) :D
3" is probably a little excessive, but thats what I've got.
Bob
Thanks for that pic, yes thats the sort of thing I have in mind. I've got several smaller 2" thick slabs that I can use for the ends and I had decided it will have to be easy to dismantle. (I'll have to assemble it after it's bought inside anyway)
Cheers
ohsoloco
Pigman, that's a nice table  :)  What kind of joinery did you use to attach the "feet" to the table sides, it looks like you have a cross-grain situation there  ???
CHARLIE
Ianab, here is a link to some free woodworking plans.  Select 'T' for table or maybe 'D' for Dining.  There is also a selection for tables.  I use it sometimes for plans and sometimes just for ideas.  It's fun to look through though and you might find it of some use. :)
http://www.woodworkersworkshop.com/resources/index.php?cat=102
Charlie
pigman
Quote from: ohsoloco on August 01, 2005, 05:31:46 PM
Pigman,  What kind of joinery did you use to attach the "feet" to the table sides, it looks like you have a cross-grain situation there ???
The ends have a tendon in the middle that fits in a mortice in the horizontal feet. The tendon is only glued in the center 4 inches and the mortice is 1/2 inch longer than the width of the tendon.
ARKANSAWYER
If it is 3 inches thick put it on the band mill and bust it in half and book match the top.
ARKANSAWYER
QuoteIf it is 3 inches thick put it on the band mill and bust it in half and book match the top
Yeah.. except it's already 3 to 4 ft wide  :D
Yeah I know.. make 2 tables... just need to find a 48" bandsaw now. :D
Thanks for the idea though :)
Larry
Started on the third one for this year.  This one is butcher block style in red oak.  The templets for the leg's are laying on the top.  I spend more time doodling on paper to get the proportions right than I do on anything else.
Looks like Bob the table maker, ;D got the proportions right on his table...think I might make me a new templet for my next table. 8)  Impressed with Arky's table also...what kind of wood is it? :)
